isuues with the body frame? Options
pretorius
#1 Posted : 19 August 2018 13:51:41
Rank: Amateur Level 1
Hi,
I have a issue with issues 71 and 72, I have two keft BF-20`s, so for the right BF-20 I had to flip it upside down to fit, also the one of the rods, will not tighten, no matter what screw I use tried them all, even moved it around the frame it will not tighten no matter where I put it, also tied different ends, all the other rods are ok.
Has anyone else had any of these issues?.
Can this be seen as a problem in the futre of the build?
cheers
#2 Posted : 19 August 2018 14:14:40
If you look at the official build part #BF-20 is simply reversed to fit in position which is noted in the instructions on page 13 picture 5, as the parts are identical. As for the rod it sounds like its a faulty part so contact C/S for a replacement.
pretorius
#3 Posted : 19 August 2018 14:23:54
Ah yes, re-read it, thanks for that, your right.
I will contact customer services about the rod..
cheers
semaj
#4 Posted : 20 August 2018 21:07:50
if you look through my build diary, you will see i had a similar problem with some of the rods too. it seems as though the holes havent been drilled deep enough. rather than needlessly ordering a replacement i simply filed down the lenght of one of the screws.
Building:
Complete:
pretorius
#5 Posted : 21 August 2018 08:32:15
Semaj,thanks for your reply, a quick and simple fix, I had the same problem, three rod ok one not.
Looked at your build log, very good indeed, and some very helpfull fix`s within the build that I will take on when I get to that point.
cheers
semaj
#6 Posted : 21 August 2018 19:09:45
no probs and happy to help.
Building:
Complete:
This page was generated in 1.794 seconds.
