Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,273 Points: 22,126 Location: Northamptonshire, England
Great work Lasio, stunning work Mark Regards Markwarren (Mark) Admin
Ahoy Shipmates! Issue 92 continued:- pendants added to the fore mast - shrouds added to the main and mizzen masts Two questions to the experts regarding these parts: 1) Later on, will there be anything attached to the pendants, or they will hang loose? Unfortunately even if a soaked the thread with diluted PVA glue and let them dry, after removing the weights they still hang in an "unnatural" way, slightly splayed out. See them in the background of the first photo below. If there will be nothing attached, can I glue them to the side of the bibbs to make them hang vertical? 2) Shall I seal the shroud reef knots around the mast top? It's not mentioned by the magazine. Optional extra:As some of you, I bought little crowns to be added to the end of the catheads. They sprayed with primer. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
 Looks good to me Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hello Guys, Quite a few photos this time... Sorry if you'll find them too much. Issue 92 completed:- all lower shrouds fitted - as I opted to have the deadeyes being black, I sprayed them black - all deadeyes fitted to the shrouds As I found difficult to make the hidden knot for the deadeyes as per the magazine instructions (I'm not an octopus with eight hands  ), I used the same method which I made the pendants with. First with a spare thread I made a loop with a tight tie. Then I set the desired tension with the deadeye in place and then secured the deadeye with the 0.25 thread, sealed with a single knot. Then wrapped the thick thread working from the deadeye and finished with a half hitch. Issue 95:- to avoid the shrouds being tangled jumped to this issue to loosely secure all of them with lanyards It's not mentioned in the magazine, so I'm not sure it's correct or not, but I mirrored how the lanyards were lead through the deadeyes. I used the magazine way (starting from the left hole on the upper deadeye) of the left hand side of the ship, while on the right hand side I started from to right hand hole. - dummy cannon barrels were fitted behind the mizzen shrouds (issue 100) beforehand Optional extra, cathead crowns: - whole crown painted gold - details added with white, red, green - blue added to imitate holes - crowns glued to catheads I think the end result is quite good relative to the scale Display cabinet:- worm and worm wheel arrived for the drive - plastic gears arrived for sliders - lots of other parts are in order (bearings, bushings, threaded rods) gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Hi Laszlo, Lovely update!!! I enjoy all the pics - the more the better. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Lovely pictures Laszlo. Looking excellent. Mark Regards Markwarren (Mark) Admin
That's some very fine work on the cathead crowns Excellent level of detail all round Regards Gray
Hi Laszlo, i´ve been on a vacation for 2 weeks and your progress in the meantime is unbelievable!
Greetings, Walter
Very nice work Laszlo, she's looking superb.
Joined: 01/05/2015 Posts: 43 Points: 132 Location: Clearwater, Florida USA
Fantastic build. I just finished reading your diary from the beginning. I just started my build and will be referencing your efforts often.
Hello Everyone, Thanks for the great comments, much appreciated. @CRphoto, I'm glad that you'll find my diary useful during your build, I'm sure you'll enjoy to make your own Victory. Issue 94 completed:- pendants added to the fore and main topmasts. As all of the pendants were hanging "unnaturally splayed out" I glued them to the side of the bibbs, to ensure they hang vertical. - deadeyes added to the tops - shrouds added to the topmasts - deadeyes fitted to the shrouds and then loosely secured with lanyards Issue 95 continued:- lower shrouds tensioned, lanyards tied up - futtock staves added to all masts. I used 0.25 mm thread to tie them to the shrouds as I found that 0.5 mm makes a too big knot. Display cabinet side project: - further parts arrived, now it's quite a wide collection: shafts, threaded rods, gears, bushings, bearings, shaft collars, dowel pins, motor, rope - next step is to turn the big spools for the rope from the nylon rod gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Another great update to your build and very well done too....  .. Think this is a build you should be very proud of, it is going to be a truly beautiful display piece when finished......  Regards Alan
Great work Laszlo. You are doing such a great job on her, taking time to get thing right certainly shows when build a quality model. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
This is really turning into a build of excellence. Keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Excellent work, beautiful build Mark Regards Markwarren (Mark) Admin
Ahoy Shipmates, Thanks for the nice comments. Issue 95 continued:- catharpins added to all masts. First I was a little hesitant what knot I should use to fix them to the wire, because it's not mentioned by the magazine. I tried half-hitch, cow-hitch, but I found them a) too big, b) difficult to make the catharpins to the right tension between the two shrouds. So I ended up with a single knot (I think it's called overhand knot), with this it was easy to set the tension and the knots were still small. Then the trouble came...  The ship was captured by over-scaled pirates and other creatures. My son came and show me what he did and asked if they can go to the ship... I must had a weak moment and I let them on board.  Then with a successful counter-attack the ship was cleared and I was able to carry on building. Issue 95 finished:- all futtock shrouds fixed to the futtock stave. Warning: maybe it's just me, but I strongly recommend that the thread for the mizzen mast top deadeyes (for futtock shrouds) must be longer than 100 mm (at least 120 mm), instructed by the magazine in Issue 94. I nearly ended up some of them being too short, on the worst I had only 3mm spare thread left below the binding, it was so difficult to hold it. See picture below. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Very pleased to see you managed to repel the boarding party and send them on their merry ways.....  .. All looking fab..... Regards Alan
Hello All, another day, another update. Issue 96 started:- topmast shrouds tensioned and tied off on all three masts Issue 93 completed:- gratings fitted to bow deck - bowsprit fitted and secured with gammoning. Thanks to Alan (Gandale) to advise how the gammoning should be done, I found the magazine instruction and pictures not very clear. If anybody is in doubt, on this build the gammoning should be done as shown on diagram 'B'. Thanks Alan, again. The ship is now really getting into shape, it's hardly fit onto a photo. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Happy to be of help Laszlo... You're doing a fab job with your build, she looks great..... Regards Alan
Hi Laszlo, Great work on the rigging. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Guest (11)
