80 Pages «<45678>»
Sticky Wickett
#101 Posted : 30 August 2018 08:05:00
That concludes this week's update of my build log. I still have the free flood holes to add to this section, plus 4 sea lockers and edging strip to the upper lip of the lower deck before i can move onto the next phase of modifying the conning tower.
I'm on my holsBigGrin next week so my next update will be in a fortnight.
Thanks for looking in and your comments, have a great weekend, i willLOL and happy modelling!
Phil W.
#102 Posted : 30 August 2018 13:37:15
that looks superb PhilDrool amazing workLove regards PhilCool
#103 Posted : 30 August 2018 13:44:46
Sticky Wickett
#104 Posted : 30 August 2018 15:32:11
Thanks very much Phil!Cool It's slowly getting there!Blink
Phil W.
Sticky Wickett
#105 Posted : 30 August 2018 15:33:03
Thanks very much Andy!Cool Still a long way to go but it's slowly taking shape.
Phil W.
#106 Posted : 30 August 2018 16:29:30
Great update Phil BigGrin and some nice problem solving skills as well.
Sticky Wickett
#107 Posted : 30 August 2018 22:18:33
Thanks very much Al!Cool
Phil W.
#108 Posted : 31 August 2018 09:06:04
Stunning work, great build and a pleasure to watch.Love
Sticky Wickett
#109 Posted : 31 August 2018 11:30:03
Thank you very much Mark!Cool There's a lot of modifications on the conning tower, but it's slowly taking shape.
Phil W.
CaptnBirdseye
#110 Posted : 31 August 2018 19:16:42
Rank: Superelite
Been re-reading your diary from post 1. Your attention to detail is second to none, and skills are self evident. Great diary, and a real pleasure to follow ThumpUp
Regards Gray
Sticky Wickett
#111 Posted : 13 September 2018 07:55:35
Regards Gray
Thank you very much Gray!Cool
Phil W.
Sticky Wickett
#112 Posted : 13 September 2018 08:02:29
Good morning from 'The Dockyard'.
Well i'm back from my hols in Cornwall, back to work and back on the modelling.
This update continues with scratch building modifications and adding detail to the conning tower of my 1/48 scale model of U-boat U230.
The next step was to add the 'free-flood' holes to the lower deck of the conning tower. These 'free-flood' holes allow the sea water to flood in when the submarine is dived and prevent the structure from being crushed by sea pressure and allow drainage when surfaced.
I first marked out a pencil line around the lower deck as seen in the attached photo.
Sticky Wickett
#113 Posted : 13 September 2018 08:04:19
Another photo showing the horizontal line marked out in pencil.
Sticky Wickett
#114 Posted : 13 September 2018 08:09:52
I then had to mark out the spacings for the free flood holes. My donor model had a lot more free flood holes when compared to photos of U995 and U230's conning tower; so i went with my reference photos.
The are eleven holes each side, so after a bit of calculation I could mark out their spacings. The best thing I found for this job was not to use a ruler, but a small piece of card with the gap drawn on it in pencil. By simply placing the 'cardboard ruler' against the horizontal line, I could mark out evenly and correctly, even around the tapered areas where the steel rule struggled.
The attached photo shows my 'cardboard ruler' in action.
Sticky Wickett
#115 Posted : 13 September 2018 08:10:27
All marking out completed.
Sticky Wickett
#116 Posted : 13 September 2018 08:13:29
I then proceeded to drill out the free flood holes in various stages, using larger drills at each stage. I decided on this method so as to not 'tear' the plastic if I had gone in with the final drill size.
The attached photo shows the first hole being drilled with a 1.0mm diameter drill.
Sticky Wickett
#117 Posted : 13 September 2018 08:14:08
1.0mm diameter hole drilled.
Sticky Wickett
#118 Posted : 13 September 2018 08:17:11
I then drilled the remainder of the holes with this size drill before opening these holes further with a 1.2mm diameter drill, a 1.6mm diameter drill and finally a 2.0mm diameter drill.
Sticky Wickett
#119 Posted : 13 September 2018 08:18:17
Another photo showing the holes completed.
Sticky Wickett
#120 Posted : 13 September 2018 08:19:11
The free flood holes looking down the starboard side of the conning tower.
80 Pages «<45678>»
This page was generated in 0.647 seconds.
