19 Pages «<23456>»
jonny7england build. Options
#61 Posted : 05 July 2011 15:06:58
I boo-boo'd big time with my last attempt at carving out the wriggles on my build and landed up spending most of Sunday removing the wales where necessary and refitting them...Now, with the wales replaced, I have now begun to fit the Dolphins...Blink
That is one of the good things about this site and keeping a build diary...If you make a mistake and fail to spot it, it is great to hear from somebody who has picked up on your error and pointed it out to you so that you can correct it...thanks fellers...ThumpUp
Son of Bulwark
#62 Posted : 05 July 2011 16:27:15
Hi jonny! Cool
You might have made a boo-boo, but at least the standard of work in your boo-boo was great! just sorry I had to point it out, you put a lot of work into that I could tell.
Glad to see all is now well with your ship and you can finally move on, one day you will look back in your diary and have a good laugh about it.
It’s great to have the forum shipmates, the build diaries is a great idea! you can show the work you have done, be helped to spot problems, sharing information on the build and getting ideas for your own ship.
Nice work Jonny! BigGrin
#63 Posted : 05 July 2011 17:21:45
For my little secret of bending planks..well, I have got a cheep pair of electric hair tongs plus an electric soldering iron...the latter causing me a lot of grief from the missus because for some reason it kept on tripping the fuses in the fuse box just when she was watching her favourite TV programmes..
LOL
But, I found it best to use a plastic container (i.e in my case a sugar storage container) stand your planks inside and fill with boiling water and leave for 10 - 15 minutes, remove soaked planks with tweezers and using the same container, clamp the wet planks to the outside circumference or apply wet to your model and allow to dry at room temperature...preferably over night...when dry, it will maintain the shape to which you secured it...here are some short lengths of wood that I wanted to bend...BigGrin
Cheep and nasty...or just simple and sweet???
LOL
amipal
#64 Posted : 05 July 2011 23:43:04
To date, I've been using the "apply wet plank to model and allow to dry" method. Works well, but now that I've started work on the waterline planking, it takes too long.
#65 Posted : 06 July 2011 08:08:14
Thats what I do, works for meBigGrin
#66 Posted : 06 July 2011 19:05:04
Didn't get much time to work on my build today, but what I did do was to fit the Dolphins and soak the four pieces of 2mm x 5mm strips of wood then clamping them to the fore mentioned circular tea container that I nicked from the missus..leave them to dry over night and glue them to the bow post tomorrow...
Blink
#67 Posted : 07 July 2011 15:52:27
Managed to grab a couple of hours on my build today where I set about completing the instruction of issue 44 and finished the installation of the Dolphins and decoration of the bow post section...
BigGrin
saintsman123
#68 Posted : 07 July 2011 16:38:25
Great idea with the tea cup, it's amazing what we all use for various parts of the build. I can't remember which part or which household item I used once, but I do remember the look on my wifes face
Come on you Jimmies
#69 Posted : 07 July 2011 20:08:29
I have begun to fit the beams that support the upper gun deck of my build...although., I am not quite finished with the hull as yet as there is till work needed to be done to it to bring it up to perfection...but here are a few pictures of my latest toils...Blink
tom.ganc
#70 Posted : 07 July 2011 20:35:52
Nice one mate, keep going :)
Tiswas
#71 Posted : 07 July 2011 21:11:26
Looking good Johny, keep it up and keep smiling. You have the right attitude, don't let it get you down.
TIS
#72 Posted : 07 July 2011 22:06:53
Your build is looking 1st class, the way you dealt with your challenges was fantasticLOL BigGrin ThumpUp
#73 Posted : 09 July 2011 16:54:03
I began to fit the decking today, it could be a long slow process as I have found a fair few planks that were slightly distorted (bent) and also, when laid into position, the thickness of the planks differed. However, I am slowly plodding on, and a number of pictures will follow...
Blink
Well, I'm off to do a little more, happy building everyone....ThumpUp
#74 Posted : 09 July 2011 17:02:28
Looks great JonnyBigGrin
Foz
#75 Posted : 09 July 2011 18:13:33
Jonny.
Shes coming along very nice indead. keep up the good work and have fun with the build.
Foz
#76 Posted : 10 July 2011 16:55:57
Well, I continued with the decking today and spent a good part of my Sunday working on my build. As usual, I started like everybody else, swatting up on Mr.T's build and the instruction in the magazine..I thought that I was going well until I got to the point where I cut seven lengths of 22mm as mentioed in the magazine page 13 pat 16...I fitted them in place and continued with my build...but when I got to laying the decking on the starboard side, I found that there was a 1mm gap between the 22mm planks and the plank laid on the starboard side??Confused I checked the measurement and instruction, I even ripped the planking out and re-laid it, but still there was that 1mm gap.Cursing ..I had noticed tiny variances in the diameter and thickness of the planks, and so I will have to cut a small 22mm x 1mm strip of plank to fill the gap...Anyway, here are my pictures...as I contemplate the task of building seven cannon...Crying
Son of Bulwark
#77 Posted : 10 July 2011 17:12:36
Hi Jonny! Cool
I bet you couldn't believe it when you found that gap.
You have some 6mm x 1.5mm planks that are used to fill in the sides of the deck you won't need all of them so you could remove a small plank next to the gap and replace with a section from a 6mm x 1.5mm plank to plug the gap might look better for you mate.
It does look good now your getting the deck on mate!.
Foz
#78 Posted : 10 July 2011 17:46:42
Hi Johnny.
Shes coming along very nicely now, they really start to take shape once that deck goes in.
And i know what you mean about those guns, even following Darrens advice im struglin to make up the gun tackle but am persavering but unfortunately have to get back to the camp in the morning so no more building for a week for me. Mad
Any way keep up the great work. ThumpUp
Foz
#79 Posted : 10 July 2011 19:10:02
Hi Jonny, sorry to hear about your 1mm gap, Its to late now but I always start with a King plank running down the centre of the deck and build out from that (I did this with the Endeavour and San Fran)one Starboard - one Port - and so on then you can fit exactly at the Bulwarks.LOL LOL
#80 Posted : 12 July 2011 18:40:52
Well....fun, fun, fun??? I thought that I would take a break from the main build and put together the eleven 12 pounder cannon that I had put away safe over the past months...Shouldn't take me long?? He said...famous last words.I started by separating all the necessary parts of the cannon into individual sections around 10am this morning...By eleven I had sanded the wooden parts down and by midday I had begun to super glue the main part of the gun carriage together (including my fingers) By 1pm I began to paint the barrels, then the wheels. At this point, I realized that these cannon will not be completed in one day?? Maybe two...we'll see?? So here are a couple of pics of my fowl up so far...
LOL LOL LOL
Oh!! By the way fellas...I finally found out what the two nails that came with each cannon were for???
TO KEEP THE LITTLE PESKY BRASS BITS STILL WHILE YOU PAINT EM!!!!
LOL LOL LOL
With luck, I will post pictures of the finished product tomorrow??? Well maybe Thursday...Crying
Guest (12)
19 Pages «<23456>»
This page was generated in 0.567 seconds.
