I got my first month of the x-wing build.So here are some pictures of what you get. darbyvet attached the following image(s):
Stage 1 is pretty simple.Attach the 2 pieces of the canopy and build part of the cannon. I dont know if this is the final canopy or not because it is the wrong color.You do need a bit of force to click the 2 parts together. The paint on the parts is pretty good.Not perfect color between parts, but I think a light blending coat would cover that up and tone down the weathering. darbyvet attached the following image(s):
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,705 Points: 17,267 Location: ipswich
A nice beginning.
Mind you - I find it a bit strange to see 'Disney' next to the Star Wars logo...
The laser cannon has a thick piece of flexible clear acrylic which is the fiber optic for the laser effect.There is considerable light leakage from the fiber.I am going to try painting the outside of the fiber to block the leak and I will be making a part that connects the LEd to the fiber.As is the fiber optic just abuts the LED and there is a lot of light leakage around it.The manual says you can paint the interior of the laser cannon black to block out some of the leak and I will be doing that also.I put the laser cannon next to a 1/72 x-wing so you really get a feel for how big this is going to be. darbyvet attached the following image(s):
The R2 D2 is pretty nice.It has a LED to light up the lights on the dome.IT too has some light leakage, but I think painting the interior black will probably block most of it.The head is also on a spindle so it can turn from side to side. NOTE there are 2 very small parts to add to R2s foot detail.Both of these stuck to the packaging when I opened them so be very carefully when you open the packages that you dont accidentally throw these parts away.Here is a pic of R2 and the part. darbyvet attached the following image(s):
There are parts to start assembly of the cockpit base too.There are metal parts and these are pretty heavy. They assembled with no problems darbyvet attached the following image(s):
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,282 Points: 22,153 Location: Northamptonshire, England
Nice start Carl. This is going to be one cool build. Mark Regards Markwarren (Mark) Admin
Great to see another X-Wing build up and running Another one for the list when launched in the UK
Good to see you running with this one Carl. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Off to a great start Carl, will be following your progress on this..... Good luck with the build.... Regards Alan
 Nice start and looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Good to see your build get underway, nice job.
Great start Carl  looks an quality kit  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Joined: 30/05/2017 Posts: 29 Points: 93 Location: USA
You guys are killing me. I've got 3 models going already, and now I may need to add this one!!!! Current Builds: R2D2, Millenium Falcon
 Go on, you know you want to Let’s be honest here you won’t be the only one thinking that! It does look a great kit
Great start Carl  looks like some great quality parts, look forward to seeing it take shape. Al
