3 Pages <123
Rogers 119 by Occre Options
#41 Posted : 21 June 2018 16:58:40
Looking good Gil BigGrin great idea to use your Victory jig.
#42 Posted : 21 June 2018 18:15:51
Good to see this up and running again Gil
#43 Posted : 22 June 2018 00:08:24
So good to see you able to get back on this one.
Cool Cool Cool Cool Cool
Look forward to the next update.
#44 Posted : 22 June 2018 07:12:14
BigGrin Glad your back on this beast and nice workCool
#45 Posted : 22 June 2018 08:36:57
Great to see you back working on this Gil, looks amazing....Drool Drool
GilShapley
#46 Posted : 29 August 2018 14:21:03
have had only a little time on this build (Property move with the necessary improvements/updating have taken priority).
Nearly completed the engine and have started on the tender.
the engine as you will see in the picture has a lot of parts the "stick out" and are therefore very easy to dislodge and have to be re glued. There will be some touching up of the paintwork required. Bending the pipework to fit was "interesting" I don't remember having the same problems when I built the Jupiter. I did not use the copper/brass wire provided with the build but brass rods which I already had. I could not get a good look with provided wire. It was not easy to get the kinks out of the coil, I think the rods look better.
More to follow soonish
Current Build:-
#47 Posted : 29 August 2018 20:03:31
Really nice build you have there Gil Cool
#48 Posted : 30 August 2018 07:19:56
GilShapley
#49 Posted : 09 September 2018 15:30:44
Finally finished the Locomotive now on with the tender. Have sprayed most of the parts and can begin the assembly. Will post pictures as that part of the build proceeds.
I have not glued on the cab roof as I want to be able to remove it so that the details of the interior can be seen clearly.
Current Build:-
#50 Posted : 09 September 2018 15:56:23
WTG Gil
That`s a very nice end result on the engine.
Cool Cool Cool
Look forward to the addition of the tender.
#51 Posted : 10 September 2018 07:17:48
BigGrin Looking good and nice finishCool
GilShapley
#52 Posted : 13 October 2018 08:24:54
This has been a slow build due to my moving. Its seems thing like decorating and installing new kitchens take priority. Still a happy wife means a quiet life
Just finishing the tender and Oopps it seems that when I assembled the base I forgot to install the retaining nut for the front bogies. Thought I might need to deconstruct part of the build but with a bit of lateral thinking I have resolved the problem. Drilling a 6mm hole in the top of the box I was able to install the retaining nut and attach the bogies. Will soon be finished and will post more pictures
Now you see it, then you dont
Current Build:-
#53 Posted : 13 October 2018 09:51:46
Lovely work, nice to see you back on it again. Always good to have a happy wife.BigGrin
GilShapley
#54 Posted : 13 October 2018 10:21:06
Finally I have completed this build. The Rogers 119 was one of the trains in the "Golden Spike" ceremony. In May 1869 the Union and the Central Pacific railways joined tracks at Promontory point. Leland Stanford hammered in the final spike to complete the track. This spike was made of gold.
The build instruction provided by OcCre are a "challenge" but having built several of their kits I was prepared. Having said that their customer service is one of the best I have seen. Missing,broken or replacement parts are sent by return with never any quibble.
I have not glued on the roof of the cab so that this can be removed to display the inside of the cab. The interior is comprehensive and it would be a pity to hide the work involved.
I have included a picture of the Jupiter and the Rogers 119 together and no that is not the fat controller but my tribute to Leland Stanford
Pictures attached
Current Build:-
#55 Posted : 13 October 2018 12:10:02
BigGrin Looks good Gil and well doneCool
#56 Posted : 13 October 2018 13:37:28
Looks great Gil, nice job. It certainly partners up with the Jupiter well.
CaptnBirdseye
#57 Posted : 13 October 2018 13:45:00
Rank: Superelite
Great job Gil, excellent work. They look good together don’t they ThumpUp
Love the ‘fat controller’ LOL LOL LOL
Guest (17)
3 Pages <123
