80 Pages «<678910>»
Sticky Wickett
#141 Posted : 13 September 2018 08:49:59
Starboard side.
Sticky Wickett
#142 Posted : 13 September 2018 08:50:39
From another angle.
Sticky Wickett
#143 Posted : 13 September 2018 08:51:45
The next step was to add the hinges made from 0.8mm diameter half round strip.
Sticky Wickett
#144 Posted : 13 September 2018 08:52:36
Close up of the half round strip.
Sticky Wickett
#145 Posted : 13 September 2018 08:54:07
I then cut small lengths of the half round strip to form the hinges and glued in place.
Sticky Wickett
#146 Posted : 13 September 2018 08:55:10
Starboard side completed.
Sticky Wickett
#147 Posted : 13 September 2018 08:55:48
Port side completed.
Sticky Wickett
#148 Posted : 13 September 2018 08:57:32
That concludes this stage of the lower deck modifications.
Thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin
Phil W.
#149 Posted : 13 September 2018 09:00:01
Sticky Wickett
#150 Posted : 13 September 2018 09:49:31
Thanks very much Andy!Cool
Phil W.
#151 Posted : 13 September 2018 12:57:17
Looking great as always PhilThumpUp i dare not re start mine yours will put it to shameBlink regards PhilCool
Sticky Wickett
#152 Posted : 13 September 2018 13:25:53
Thank you Phil!Cool If you complete your U96 straight 'out of the box', you will still end up with a very cool model indeed. Don't let me put you off; I'm just ever slightly mad!Blink
Phil W.
#153 Posted : 13 September 2018 15:40:44
Lovely work as usual Phil.Love
#154 Posted : 13 September 2018 16:54:57
Another fab update, great work....Drool Drool
Sticky Wickett
#155 Posted : 13 September 2018 17:00:49
Thank you very much Mark!Cool
Phil W.
Sticky Wickett
#156 Posted : 13 September 2018 17:01:16
Thank you very much Alan!Cool
Phil W.
Sticky Wickett
#157 Posted : 20 September 2018 19:41:42
This weeks update continues with scratch building conning tower modifications of my 1/48 scale model of u-boat U230.
The next phase is to build the upper deck. To start with i had to square off the original angled profile by fitting 'filler pieces' made of 0.5mm thick plastic sheet.
The attached photo shows these 'filler pieces' being marked out.
Sticky Wickett
#158 Posted : 20 September 2018 19:42:30
The 'filler pieces' cut out and filed to shape.
Sticky Wickett
#159 Posted : 20 September 2018 19:43:03
The 'filler pieces' fitted.
Sticky Wickett
#160 Posted : 20 September 2018 19:43:59
From above.
Guest (11)
80 Pages «<678910>»
This page was generated in 0.425 seconds.
