Keel (#issue 39) - Help needed Options
Mr.Quist
#1 Posted : 08 July 2011 18:03:55
Hi folks,
I just managed to glue the keel segments in issue #39 but
afterwards I found out that I did NOT read exactly enough.
Step 15 in the magazine:
Quote:
ensure that the stem is positioned 4mm below the top of the bow planks,
Mine is flush with the top plank.
Will this be a problem later on ?
I am afraid that it will be quite difficult to get the stem off.
Any advice is appreciated.
Greetings, Timm
My build diary here
HMS Victory
#2 Posted : 08 July 2011 18:27:45
Hi Timm, it means in your case that all the woodwork that sits on top of the stem will sit 4mm too high, which will need ajustment, however the bigger problem might be that the bowsprit may be too close for comfort (or may touch) with the figurehead located at the top of the stem; because your stem is 4mm higher than it should be, and therefore closer to the bowsprit, where there is only about 5mm space between the two when the stem is correctly seated.
If you can, have a go at releasing the stem and reset.
Foz
#3 Posted : 08 July 2011 18:30:24
Hi Timm
Only reason i can see as why it should be 4mm below the top is because of the wales being fitted later or the positions of the dolphins that are fitted after the wles as the holes in some parts have to line up with those on the stem.
Thibking about it that dolphin position seems more the right thing as to why its 4 mm below the top.
Hope this helps and hope you get it sorted out as you have a craqcking build there.
Foz
daffy09
#4 Posted : 08 July 2011 18:38:34
Mr.Quist wrote:
Hi folks,
Greetings, Timm
Hi Mr.Quist,
it might mean that when we get to the stage of installing the bowsprit, the front top edge of the keel may interfere with the correct alignment of said bowsprit. Do you have a piece of 10mm dowel that you could insert in the locating hole for the bowsprit to check the alignment? It should clear the top of the beak by approximately 4mm.
You'd have to ask a more experienced shipmate about how to correct this problem. I'm sure someone on here can help.
Happy building
Daffy09
Mr.Quist
#5 Posted : 08 July 2011 21:13:36
Thanks guys.
So far I did not dare to get it off again.
It is all glued with PVA.
And I am afraid, if I start putting water on it
that all the planks come loose.
Should I nail again to fix the planks before?
My build diary here
HMS Victory
Son of Bulwark
#6 Posted : 08 July 2011 21:34:17
Hi Timm! Cool
That is a problem if you want to play safe with the planks then Yes re-pin the planks before you try to remove the stem.
If you know a person with a steam cleaner with a nozzle for cleaning small areas you could use that to steam along the joint of the hull and stem on each side, put a cutting mat over the planks to protect them and point the steam jet away from the planking. You then get the steam to wet the joint with the stem and the heat as well to soften the joint (NOT TO MUCH STEAM) work from the top of the stem down to the keel. Then slowly ease the stem off, I hope this helps Timm.
#7 Posted : 08 July 2011 21:39:44
Might also be an idea to run a sharp knife blade along the edge between planking and keel to split the glue joint, good luck!
#8 Posted : 08 July 2011 21:58:39
failing the above,try hot water applied with a small brush,then you can ease it off slowly,worked for me on occations.
Mr.Quist
#9 Posted : 08 July 2011 22:39:46
Thank you so much guys
Unfortunately I did glue on the bottom of part 54, that side that faces the bow.Cursing So just cutting the sides won't work I am afraid.
@Darron: steamcleaner sounds promising, but I don't have one.
I will check tomorrow, maybe I can rent one for one day.
And if nothing helps, I will get me a big saw, cut that damn thing off and either glue it back on or get a spare part from DeAg.
Will keep you posted.
Thanks again and Good night.
Timm
My build diary here
HMS Victory
daffy09
#10 Posted : 09 July 2011 15:09:02
Hi Mr Quist,
Might I ask where you purchased the copper foil tape from that you used to trim your barrels? I've just got round to staining my barrels and spotted your pics on your build diary which looked really good.
happy building
Daffy09
Mr.Quist
#11 Posted : 09 July 2011 15:32:53
Darron, YOU are my hero of the week !!!
The steamcleaner worked perfect !!!!
I just steamed the edge between bow and planks several times, removed all water immediately, went with a knife between bow and planks and with a little bit of bouncing and pushing it came off after 5 Minutes !!
Thanks a lot, you saved my weekend.
daffy09 wrote:
Hi Mr Quist,
happy building
Daffy09
Hi Daffy,
you mean this one?
I just bought it on ebay a few months ago. Its actually being used for tiffany glas art work. Wasn't that expensive, maybe 6-7 € the whole roll.
Just enter the search term "copper foil tape" there and you will get dozens of hits.
Timm
My build diary here
HMS Victory
Dontshootme
#12 Posted : 09 July 2011 15:35:22
Heres where I got foil to do copper plating on my other build,they do all different widths http://www.tempsfordstai...nd_Edco_copper_foil.html
Son of Bulwark
#13 Posted : 09 July 2011 15:39:10
Glad To help Timm! Cool
daffy09
#14 Posted : 09 July 2011 20:57:37
Thanks Timm
This page was generated in 0.078 seconds.
