Hull painting Options
tom.ganc
#1 Posted : 09 July 2011 17:34:52
Hi there
Just quick question to Admin or Tommick. Do you know when are we painting hull? I know that there are some details to put on but it would be nice to know.
Thanks
#2 Posted : 09 July 2011 17:40:42
Hi Tom its on the official build nowLOL
tom.ganc
#3 Posted : 09 July 2011 22:08:56
Hi mate
I'm copper plating mine so lower hull painting isn't an option. I was asking about full hull painting.Flapper
#4 Posted : 09 July 2011 22:19:26
tom.ganc wrote:
Hi there
Thanks
Around issue 75
tom.ganc
#5 Posted : 09 July 2011 23:28:24
Thanks Mr T. Cool
#6 Posted : 10 July 2011 09:25:03
Sorry for wrong info TomBlushing Blink Put it down to ageConfused
eoinkm
#7 Posted : 18 January 2012 18:36:34
Rank: Amateur Level 1
Can anyone give me some advice on spray painting/airbrushing? Never done it before.
I will be painting the bottom of the hull rather than tiling and have purchased all the necessary admirality paints already. I'm not really sure how good of a painter I am since this is the first time I've done anything like this so I want to get as smooth a finish as possible.
Tomick - how to you get such a smooth copper finish at the bottom of your boats hull?
Many thanks
#8 Posted : 18 January 2012 19:17:45
Many thanks
Airbrushing is much more difficult than hand brushing. you could go for aerosol but I would recommend...
Hand paint. Mix paint thouraly, if you feel necesarry thin the paint a little to ensure it is not to thick. Admiralty paint is water based so you will need an appropriate thinner. You will probably need to apply 3 coats or so. If you have uneven coverage after paint has dried ( you can sometimes get a matt and gloss look depending on how well paint was mixed and dried) you can always give the hull a coat of varnish to even the shine. There are semi gloss varnishes that would look good.
This page was generated in 0.879 seconds.
