Issue 35 - gunport framing planks Options
StefanDV
#1 Posted : 10 July 2011 11:23:26
Hi,
Has anyone who subscribes received the gun-port framing planks in issue 35? All the planks I received seem to be the thicker 'hull-planking' planks
[Edit 2011/07/11 13h21]: Corrected the issue nr.
Atholm
#2 Posted : 10 July 2011 17:09:10
Hi StefanDV
I received my lot of mag including 34 last week I also did not get the gun port planks. Spoke to CS who has arranged for another copy to be send to me. I stressed at least 3 time that the planks I was missing were 8 off 1,5x4x300mm.
I am waiting to see what happens.
StefanDV
#3 Posted : 10 July 2011 21:02:35
It is issue 35, we're supposed to receive the last couple of framing planks Cursing Why can't they just get it right. I'm going to call them and say I need another issue 34, hopefully they can get that right!
Quintin
#4 Posted : 11 July 2011 08:22:13
occasionally there is a mix up with parts, but if you call them and let them know, they post you a new one almost immediately. I had 2 part 30, and they sent me a new issue right away, no problem.
So far, I have been happy with the customer service, as it is generally better than most we have to deal with over here.
Part time modeller, full time biker
Built: Pinta
Belle Poule (plastic)
Endeavour
Scratch build of Pirate ship "Neptune" (Based on cutter "HMS Aldebaran"
Current builds: Victory
#5 Posted : 11 July 2011 09:34:15
There appears to be confusion as to which issue contains what, and what should be used for what....
Issue 34 contains eleven 1.5x4mm planks; the 'Where parts fit' info clearly says that the 11 planks are enough to complete the entry ports on both sides and all the gun ports on the starboard side.
Issue 35 contains a further eight 1.5x4mm planks to complete the portside and stern portholes.
StefanDV
#6 Posted : 11 July 2011 13:20:00
Thanks Tomick,
Thanks for your reply, you are 100% correct. My problem is that the parts accompanying issue 35 does not contain any 1.5x4mm planks.
Phoned Customer services just now and they'll send a replacement issue BigGrin, but only in 21 days time Crying
Sietse
#7 Posted : 11 July 2011 13:41:23
Hi guys.
No complains from my side, I receive all my parts from day 1.
Sorry about your shortfall, I can say in the past post office lost my magazines, I reported it to CS and with no tantrums CS replaced them. 10/10 for Jacklin.
Albatross, build in 1982 from plans.
Hms Bounty, build in 1987 from plans.
Duyfken,build in 1991 from plans
Oosterland, build in 1998 from plans
2010 Hms Victory kit from Deagostini
In the meantime.
2011 Building MFV 1963 fishing trawler from plan.
#8 Posted : 13 July 2011 13:37:15
Hi Guys
I think you need to check issue 35. I had problems with issue 27 and CS re-issued 27, still wrong, so made a plan with spares that I had. Issue 35 does not have the spare 8 x 1.5mm x 4mm to do the frames for the gunports??, so will have to contact CS again. They are very helpful and prompt, but it appears they don't check the parts list before distribution. Holding thumbs they get it right.
StefanDV
#9 Posted : 13 July 2011 19:35:23
Except for this one, I also did not receive the correct part 31 (issue 14 I think) they sent me 4 replacement copies - all wrong, so I had to make the part myself. Same with the thicker planks which goes on top of the 2nd deck support, didn't even bother contacting them.
Let's see what transpires
Atholm
#10 Posted : 20 July 2011 16:58:00
Hi All
I received my replacement issue 35 today. Still no 1,5 x 4mm planks. I have asked CS to send me a copy of issue 34 which has the correct planks and they agreed. All I have to do is wait another 2 to 3 weeks.
StefanDV
#11 Posted : 20 July 2011 22:07:50
Angry Crying Sorry to hear that.
Not wanting to go through that I ordered a replacement copy of issue 34. Was dispatched on the 18th so hopefully not much longer.
This page was generated in 0.061 seconds.
