missing leg plugs at issue 89 Options
figuerres
#1 Posted : 13 October 2018 17:04:11
i am now up to issue 89. both legs have been built with the parts i have got to date. but one of the legs needs 4 curved plugs for the "battery pack" on the inner side of the leg.
as the kit often ships parts in groups that are not allways together and i do not recall any prior issue listing the plugs i am wondering if the missing plugs should have came a while back or will they be in the final issues from 90 to 100.
are other folks missing a set of plugs for one leg ?
or did i miss a set of plugs in one of the other issues ?
i do not need any other leg parts just the 4 small plugs so if i need to get them i hope i do not need to order a whole issue to just get 4 plugs to cover the screws.
Spudtrooper37
#2 Posted : 13 October 2018 17:43:56
Mines the same, I'm sure they will be in the last 2 issue's
Darren
Have an AWSOME day and may the Force be with you always 😉
Building: Millennium Falcon https://forum.model-spac...sts&t=14381&p=7 - Building: BTTF Delorean - Building: Dom's Dodge Charger
- Building : X-Wing https://forum.model-spac...aspx?g=posts&t=34899
#3 Posted : 13 October 2018 18:03:56
BigGrin The 4 plugs will be in issue 100Cool
This page was generated in 2.119 seconds.
