Wrong potition of the hole on the Head Dome for the main camera Options
nsotiriou
#1 Posted : 14 October 2018 16:40:48
Rank: Beginner Level 1
Hello there,
I have discovered today something very bad for my project. As you can see from the pictures there is a problem with the big hole on the dome, the one for the camera. I have received with issue 51 the dome and as you can see it is the wrong dome. From the official buid the hole must be in different position as it is not on my Dome. Wrong hole from the factory perhaps. Please help.
This is the oficial right version of the hole
Nicholas
Wrong Picture.jpeg (86kb) downloaded 162 time(s).
nsotiriou attached the following image(s):
#2 Posted : 14 October 2018 17:29:35
Hi Nicholas contact C/S for a replacement dome.
DC-Zol.
#3 Posted : 14 October 2018 18:36:43
nsotiriou wrote:
Hello there,
Nicholas
Sorry you’ve had this Nicholas gutted for you, but thank you for posting this information
Hope it won’t set you back too far - you might want to buy some 3M double sided tape for when reattaching the blue panels
I have asked my (unofficial) R2 Build FB Group members to double check theirs as it may not be apparent straight off when building.
Kind regards
Darin
Spudtrooper37
#4 Posted : 14 October 2018 19:11:58
Oh wow, I feel for 😞
Darren
Have an AWSOME day and may the Force be with you always 😉
Building: Millennium Falcon https://forum.model-spac...sts&t=14381&p=7 - Building: BTTF Delorean - Building: Dom's Dodge Charger
- Building : X-Wing https://forum.model-spac...aspx?g=posts&t=34899
IanW
#5 Posted : 14 October 2018 20:00:30
Just to be clear, OP's camera hole in the dome extends left until the left-hand edge is almost aligned with the two-display panel.
The correct dome has this left-hand edge about halfway along the smaller, non-display, blue panel underneath it (the one in between the circular hole-cut panel and the two-display panel).
Sometimes I find it hard to spot the actual problem, so I thought this might help :-)
semaj
#6 Posted : 14 October 2018 21:07:26
oh wow, this isn't great.
before you get carried away stripping everything, i would slide the lens cover in place and see how it looks. if it covers the gap, and the camera mounting position looks good then everything should be ok. its difficult to tell if the cut out is in the wrong place, or just been cut a bit too big.
Building:
Complete:
IanW
#7 Posted : 14 October 2018 21:24:24
Looking at the two pictures, it seems the hole is cut too far to the left; it looks the same size though, based on where the right-hand edge aligns.
Wrong Dome
Right Dome
nsotiriou
#8 Posted : 14 October 2018 21:27:20
Yes and that’s why it is impossible to put the blue eye correctly. The inner section of the Dome is ok.
semaj
#9 Posted : 14 October 2018 21:35:47
Wrong Dome
Right Dome
i saw that, but the spacing on the opposite corner to the projector hole looks the same, which made me wonder if it was just the hole cut too big? as i mention, try fitting the eye cover. if its bad then deffo you need a replacement dome. if its ok, and hidden then just go with it. it looks like we fill the space with some foam strips in the future anyway. at the end of the day, the eye piece connects to the inner framework, so if thats ok, then there shouldnt be too much of a problem if the part covers the hole.
Building:
Complete:
#10 Posted : 14 October 2018 22:12:34
In stage 10 you get the 'Camera Lens Mount' that has slots in it that marry up with the slots in the dome frame, you can see the lower slot in the pictures. The lens mount can only travel from right to left when fitted to the dome until it locks in place. The cut out in Nicholas's Dome is too far to the left so there will be a gap on the left side when it locks in place.
semaj
#11 Posted : 14 October 2018 22:26:17
fair enough. just thought id put it out there to try, if it saves ordering a replacement and stripping whats already built. never mind.
Building:
Complete:
nsotiriou
#12 Posted : 15 October 2018 00:01:24
It is clear....
semaj
#13 Posted : 15 October 2018 22:19:21
nsotiriou wrote:
It is clear....
wow, i see what you mean. gutted for you mate thats pretty bad OhMyGod . shame you didnt spot it sooner . good luck with getting the replacement and swapping over. as suggested, get some decent 3m double sided tape for re sticking the panels in place and it shouldd be ok.ThumpUp
Building:
Complete:
nsotiriou
#14 Posted : 16 October 2018 12:35:52
Hi,
I contact C/S and they agree to send me a new one. I hope that the only one with the problem was mine and not a piece of a late production with this mistake. I will wait to see the replacement and I will post to you all, because if there is a massive problem with the last production the problem will be very serious. People with the dome all ready have check this little detail before is to late, before you place the small blue panels. Imagine if the last shipment from the builders factory have this problem, how difficult will be for Model - Space. Someone have to inform to stop sending out the wrong dome until it is checked to be the right one. This message is useful to arpurchase which he was very polite and clever to identify the problem directly.
Thank you.
#15 Posted : 16 October 2018 12:54:07
nsotiriou wrote:
Hi,
Thank you.
A random stock check has already been made and none found to have the same problem. Also, there has not been any similar complaint within the UK or anywhere else in the world. Therefore at this point we can only assume that this happening is a one-off rogue dome and the manufacturer made aware of this. Thanks for bringing it to our attention.
This page was generated in 1.761 seconds.
