13 Pages «<89101112>»
Anakin Skywalker's Podracer Diorama Options
#181 Posted : 15 October 2018 14:10:36
Thank Graeme, still a lot to do. Keep putting off the electronics, but I’m going to have to face that soon.
#182 Posted : 15 October 2018 19:31:46
Cool Looking good Mark look forward to seeing your progress.BigGrin
godan61
#183 Posted : 15 October 2018 19:59:55
We all have that one thing we keep putting off that dread of make or break certainly can relate to that.
#184 Posted : 15 October 2018 20:11:58
Thank you guys for your kind words and support.
#185 Posted : 22 October 2018 07:55:15
I have now finished the display case. I have primed it several times, sanding to get a smooth finish before painting it black. I then drilled the holes for the switches and a hole in the rear for the mains power adapter. I masked off the top area as this will be covered with the diorama. I have also placed the switches in to give an idea how it will look.
Now onto the rock part. I originally was going to use bark, but after experimenting with this it didn’t look right for what I wanted to achieve. So, I bought some foam blocks and a heated foam cutter, which by the way is the easiest way to cut this stuff. I experimented with a lot with different types of glues and paints first, before making the decision to use it.
The first picture is how I wanted the rock formation to look like, although it will be a redder/sand colour when finished. I started to carve the block in different pieces, this was a job for outside because of the mess it makes. The last pictures are what it came out like after several hours of carving with a knife and a wire brush. This was then sanded to smooth over in places. Some minor tweaks are needed before I paint the whole thing with watered down PVA glue.
More soon.
#186 Posted : 22 October 2018 08:47:46
Stunning, love the effect you've achieved. Going to be amazing when finished.....Love Love
#187 Posted : 22 October 2018 14:10:31
Hi Mark the rock looks amazing. very well doneBigGrin Cool Drool
#188 Posted : 22 October 2018 16:36:49
Interesting watching all this come together Cool
#189 Posted : 22 October 2018 19:02:09
Thank you guys for your comments and support.Cool
#190 Posted : 22 October 2018 19:09:29
Great job on the base Mark and that rock looks very realistic too Cool
#191 Posted : 22 October 2018 20:17:27
that looks fantastic.Cant wait to see the finished model.
#192 Posted : 23 October 2018 00:00:02
That`s an amazing backdrop WTG
Cool Cool Cool
#193 Posted : 23 October 2018 07:23:28
BigGrin Very nice work and well doneCool
#194 Posted : 23 October 2018 08:03:27
Thank you guys for the kind words. Getting interesting now. Still g
Haven’t started the electronics.Crying
#195 Posted : 29 October 2018 08:25:07
This seems a small update, however, this has taken longer than carving the rock formation that I did last week. First, I used the triangular template to work out where the supports will be placed. I then made the three supports out of brass tubing, bending the tubes with a miniature pipe bender. This took some time to work out the angle of the bend. I used the model, attaching it to the tubes for accuracy. The third tube will be placed into the base rather than the rock.
I have also added some smaller rocks, made from pieces of foam, for effect around the main formation. More will be added at a later stage. I then painted the foam rock with watered down PVA glue to seal it. Another coat will be given before any paint and pigments are applied.
More soon.
#196 Posted : 29 October 2018 12:07:57
Fantastic job with the rock formation, looks very realistic. This is going to be a very impressive diorama when finished.
#197 Posted : 29 October 2018 17:07:25
Wow BigGrin really loving your work MarkBigGrinDrool that foam rock face is brilliant and loving your home made baseLove Love Drool regards PhilCool
godan61
#198 Posted : 29 October 2018 20:56:13
Loving the rock diorama really nice gonna make the pod racer really stand out
#199 Posted : 30 October 2018 08:04:34
BigGrin All looking good Mark and nice workCool
#200 Posted : 30 October 2018 08:45:05
Thank you for the kind comment everyone, hopefully it will start to take shape a little more now.Cool
This page was generated in 0.486 seconds.
