80 Pages «<1516171819>»
Sticky Wickett
#321 Posted : 18 October 2018 08:00:40
I then glued in two tiny blocks of 1.0mm square plastic strip to support the mesh grille.
Sticky Wickett
#322 Posted : 18 October 2018 08:02:04
Using PVA glue I could position these small blocks so that the mesh grille sits flush with the top of the intake.
Sticky Wickett
#323 Posted : 18 October 2018 08:05:24
I then removed the mesh grille once I was happy it aligned correctly. I then glued in the place the small, support piece I mentioned before for the box section.
Sticky Wickett
#324 Posted : 18 October 2018 08:06:31
The profiled box section piece mentioned at the start of this post was then glued in place.
Sticky Wickett
#325 Posted : 18 October 2018 08:08:00
Completed diesel engine intake box section completed on the port side.
Sticky Wickett
#326 Posted : 18 October 2018 08:08:41
Starboard diesel engine air intake box section completed.
Sticky Wickett
#327 Posted : 18 October 2018 08:10:36
Mesh grilles fitted to both engine intakes, completing this stage.
Sticky Wickett
#328 Posted : 18 October 2018 08:20:12
The next stage of my modifying the conning tower is the addition of a scratch built radar antennae [FuMO-30] that locates on the port side.
In 1942 the FuMO-30 was introduced having replaced previous versions. Differing in design, this radar consisted of a rectangular wire mesh antennae.
Using my 1/72 sale donor model to get the overall height and width, multiplying these dimensions by a factor of 1.5 to resize to 1/48 scale, i drew out a rough sketch to act as a guide. I also heavily referenced photos of U995, which also sported the FuMO-30, to make the small parts required.
The first step was to make the base as can be seen in the attached photo.
Sticky Wickett
#329 Posted : 18 October 2018 08:21:16
Next job was to make the outer frame work using 1.0mm square strip. Very fiddly work I have to say.
Sticky Wickett
#330 Posted : 18 October 2018 08:23:35
Frame work completed and checked for alignment against an engineers square, or could it be goal posts for the crew!LOL
Sticky Wickett
#331 Posted : 18 October 2018 08:25:53
Framework attached to the base. At this stage I also made the cut outs in the base and marked and drilled a centre hole in it with a 1.0mm diameter drill for the mast location.
Sticky Wickett
#332 Posted : 18 October 2018 08:26:45
From another angle.
Sticky Wickett
#333 Posted : 18 October 2018 08:28:54
Next up was the addition of angled support pieces for the vertical uprights.
Sticky Wickett
#334 Posted : 18 October 2018 08:29:48
Both angled supports fixed in place.
Sticky Wickett
#335 Posted : 18 October 2018 08:31:59
I then trimmed the tops and added small sections, as indicated by the tweezers in this photo, to add strength to whole structure.
Sticky Wickett
#336 Posted : 18 October 2018 08:33:51
The attached photo shows both of these small supports in place. They provide rigidity to the angular and vertical sections.
Sticky Wickett
#337 Posted : 18 October 2018 08:37:31
Note that all of the supports I have added so far to make the radar antennae follow exactly the pattern used on U995.
A further, tiny support piece added inbetween the angular and vertical framework.
Sticky Wickett
#338 Posted : 18 October 2018 08:38:35
The other side completed in the same way. By now, the whole structure was a bit easier to handle.
Sticky Wickett
#339 Posted : 18 October 2018 08:39:14
The first of three horizontal bars fitted.
Sticky Wickett
#340 Posted : 18 October 2018 08:40:13
Second horizontal bar added.
This page was generated in 0.496 seconds.
