Absolutely outstanding ian  real credit to you  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Stunning work. Done a great job on the painting. Chris 😎 On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Thanks to every one that looked in and left comments they are very much appreciated. Round two with the second figure. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Ian, if the second figure turns out as good as the first, you will have one stunning centre-piece
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Very nice indeed Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Very impressive Ian, very impressive indeed..... well done.... Regards Alan
Thanks to every one that looked in and left comments they are very much appreciated. The second figure has been cleaned up. and under coated with primer. painting will start this week. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Second figure looks impressive too Ian and I look forward to following your progress with it.... Am sure it'll turn out to the same very high standard..... Regards Alan
 Looking good Ian and very nice start on the 2nd bust Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice work Ian, looking forward to seeing the second bust. Mark Regards Markwarren (Mark) Admin
Beautiful job on the first bust, can't wait to see the second take shape.
Thanks to those that looked in and left comments. very much appreciated. the breast plate has been painted using Darkstar Bright Steel Paint, left to dry and buffed up with a cotton bud. the three colours of British red coat where then painted round the neckline of the breast plate and the hem at the bottom, then this was also painted round the frill of the arms and eppauletts. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
The white frill round the neck and waist have been added. Three coats of the French blue have been used on the arms and the white frills have been added. The brass chain straps of the breast plate have been added, and the rivet`s of the breast plate where painted with copper paint. The face was painted using tones of flesh colour paints. The collar was painted using three tones of French blue and a yellow trim. The chinstrap and upper helmet was painted in brass. Thanks for looking in. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Very nice work Ian especially with the metallics. I think figure modelling is one of the hardest genres in model making and one that most modellers deliberately avoid, so well done you for having a go.
I bet you're enjoying it though, even if it is difficult?
Kev  Per Ardua Ad Astra
Very impressive Ian, look forward to seeing more..... Regards Alan
Lovely work Ian, looking good. Mark Regards Markwarren (Mark) Admin
Thanks for the comments guys, they are very much appreciated. Kevin the hardest part of doing figures I find is getting the faces looking right after a few figures you start to get the hang of it. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
ian smith wrote:Thanks for the comments guys, they are very much appreciated. Kevin the hardest part of doing figures I find is getting the faces looking right after a few figures you start to get the hang of it. Can only agree with you Ian, the more you do the better your technique becomes... I'm finding the same with the small decorations on the Vasa, the more I do the more I learn..... Regards Alan
Exactly, practice makes perfect as they say and it can only get better once you've evolved a system that works - well done again and keep up the good work.
Thanks for the comments Alan and Kev. The head of the figure has been glued on then darkstar bright steel was painted onto the helmet. Three shades of black where added to the turban and the horse hair on the back of the helmet. The sword was glued to the sword arm. The reigns on the other arm have been painted in in black. I then used black shaddower to age the brass parts of the helmet, Breast plate, and round the hands. the figure was then glued to the base. The only thing left to finish is the rifle which needs to be painted some more. Thanks for looking in. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
