80 Pages «<1819202122>»
Sticky Wickett
#381 Posted : 22 October 2018 09:20:28
BigGrin Looking good Phil and some cracking figures you have found to enhance your buildCool
Thank you Andy!BigGrin Cool Yes, I was quite surprised when I found the Kommandant figure in 1/48. Never heard of Andreas Miniature of Spain before either who supplied it.
Phil W.
Garth
#382 Posted : 24 October 2018 15:05:58
Hi Phil,
Awesome work, well done - great work on your radar.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
Sticky Wickett
#383 Posted : 24 October 2018 20:09:59
Garth wrote:
Hi Phil,
Kind regards,
Garth
Hi Garth, thanks for looking in mate!Cool Glad you like the work so far!
Phil W.
kpnuts
#384 Posted : 24 October 2018 21:05:54
Amazing additions mate.
Sticky Wickett
#385 Posted : 25 October 2018 09:43:24
Thanks very much Ken!Cool
Phil W.
#386 Posted : 25 October 2018 13:50:18
Great work as always. Some great finds on the details, it's going to look very impressive.
Sticky Wickett
#387 Posted : 25 October 2018 15:34:06
Thank you very much Graeme!Cool. Another weekly update to follow later this evening.
Phil W.
CaptnBirdseye
#388 Posted : 25 October 2018 16:12:23
Rank: Superelite
Hi Phil,
There's a lot of fine detail you've added there ThumpUp
You must have the patience of a saint, and the eyes of a hawk!
Excellent results thoough Drool
Gray
Sticky Wickett
#389 Posted : 25 October 2018 19:29:04
CaptnBirdseye wrote:
Hi Phil,
Gray
Thank you very much Gray!Cool I'll admit, i do have plenty of patience, but not without plenty of planning beforehand so i fully understand how to achieve the end result. Eyes of a hawk?LOL In the past maybe, now i wear glasses for all my modelling work!Blink
Phil W.
Sticky Wickett
#390 Posted : 25 October 2018 19:41:12
This weeks update continues with modifications to the conning tower of my 1/48 scale model of U-boat U230.
Last week saw me scratch building the wire antennae radar mast and this week I completed it by adding a few more details.
The attached photo shows the first of three terminals being fitted. Made from 2.5mm round plastic rod, cut and filed to length, with a 1.0mm hole drilled through the centre.
Sticky Wickett
#391 Posted : 25 October 2018 19:42:42
The three terminals fitted, with the central terminal slightly off centre to the top and bottom as per U995.
Sticky Wickett
#392 Posted : 25 October 2018 20:14:49
Earlier in the week I ordered some 1.0m diameter brass rod. In this photo, I've cut a small length and bent it to connect the central terminal to the wire antennae frame. In reality the signal would then be transmitted down the mast and onto the Radar Shack to be read by a radio operator.
Sticky Wickett
#393 Posted : 25 October 2018 20:16:07
Brass rod bent and fitted.
Sticky Wickett
#394 Posted : 25 October 2018 20:16:39
From another angle.
Sticky Wickett
#395 Posted : 25 October 2018 20:18:43
Second terminal connected to the wire mesh antennae frame via 1.0mm diameter brass rod.
Sticky Wickett
#396 Posted : 25 October 2018 20:19:32
Close up.
Sticky Wickett
#397 Posted : 25 October 2018 20:20:36
The third and final terminal connected with the brass rod.
Sticky Wickett
#398 Posted : 25 October 2018 20:24:15
The attached photo shows the first of two paddle shaped receptors. Made from 0.5mm thick plastic sheet and drilled out to accept a length of 0.5mm diameter brass rod. This will then attach to the antennae frame. Very tiny!Blink
Sticky Wickett
#399 Posted : 25 October 2018 20:24:46
The second of the receptors.
Sticky Wickett
#400 Posted : 25 October 2018 20:26:23
I then filed each one to round off the corners as per U995. The attached photo shows both receptors shaped and contoured.
Guest (11)
This page was generated in 0.908 seconds.
