Unused part 7 parts & missing rubber grommets Options
Philip
#1 Posted : 26 October 2018 13:50:22
Rank: Newbie
Hi, I am a little concerned that (unless installation in issues 99-100 not yet released) there does not appear to be instructions to fit/a use for, the two very small dicast parts from issue 7?
Also, I have 4 angled rubber screw hole grommets from issue 47 that appear to be for the bottom of one of the legs but with no instructions so far to install...plus, I am 4 short for the other leg base. Is this an oversight? Or will there be another 4 angled white rubber grommets supplied in the last two issues? Phil
IanW
#2 Posted : 26 October 2018 14:05:35
We've had confirmation that some other leg parts are going to be fitted in Issue 100, so I wouldn't worry yet, Philip; the amount of work involved in each Issue has been steadily increasing throughout the project so I'm fully expecting there to be a big final session.
Philip
#3 Posted : 26 October 2018 14:16:17
Rank: Newbie
Thanks for the reply Ian. That’s reassuring to hear. Phil
figuerres
#4 Posted : 26 October 2018 17:11:06
some of the rubber plugs will be in the last issues, i had the same question and got a reply on that. also i think two die cast parts we got will not be used, they might have been for the hinge for the flap on the light saber, i think they changed the hinge but still shipped the old one.
i have the same parts and so far nothing missing or not working.
Philip
#5 Posted : 26 October 2018 17:22:58
Rank: Newbie
Thank you for your reply. Yes, that makes sense regarding the hinged panel.
This page was generated in 1.750 seconds.
