5 Pages <1234>»
micks E type jag build Options
turilacoste
#21 Posted : 28 October 2018 07:00:50
Rank: Newbie
mogwai wrote:
Issue 12
Parts
Engine block and clutch bellhousing (right side)
Starter motor
Distributor
This issue we decide if we want to repaint the engine block, black gold,and silver to pick out the bolts,also painted the top and bottom of the distributor black, the starter motor was deseamed and painted black,then it's fit the starter motor, the distributor, then add the carburettor assembly, cheers mick.
Hello Mogwai, I am a beginner and I would want to know the correct procedure to repaint the already colored parts.
Can you/he/she be painted above or it needs to polish up before and as to do him/it?
It excuses my English, but I am Italian and I know little your language.
Thank you and compliments for your model.
#22 Posted : 28 October 2018 09:35:39
Looking really good so far.
There's just so much scope for adding extras and details to this model.
Love the engine paintwork.
Roy.
#23 Posted : 28 October 2018 13:53:19
Hi as regarding the engine painting I just taped off the bits I not want painting. And prepped the rest with bit of wet an dry paper before painting to give a key to the paint,then it was just brush applied with tamiya semi gloss black, then added the gold to the ports, hi Roy I'll be pinching some your ideas as I intend to carpet with dolls house carpet,and will be doing the leather trim to, thanks to all who looked in cheers mick.Blink
#24 Posted : 03 November 2018 17:09:33
Hi done lot more on this so going to take a while to catch up with diary
Issue 16
Parts
Passenger door
Door handle
Just a case of screwing the door handle on this issue.cheers mick.BigGrin
#25 Posted : 03 November 2018 17:14:09
Issue 17
Parts
Passenger door window
Hinge
Hinge retainer
Here we just attach the window and hinder to the passenger door. Cheers mick.BigGrin
#26 Posted : 03 November 2018 17:21:28
Issue 18
Parts
Passenger door trim surround
Passenger door trim panel
Passenger door handle
Passenger window regulator handle
Chrome finishers
Arm rest
Here we fit all the parts to the inside of the door.cheers mick.BigGrin
#27 Posted : 03 November 2018 17:38:51
Issue 19
Parts
Right hand inner side member
There's no assembly at this point.cheers mick.BigGrin
#28 Posted : 03 November 2018 17:45:15
Issue 20
Parts
Right upper wishbone
Right lower wishbone
Right suspension up right
Here we just screw the wishbones to the right hand inner side member provided last issue Cheers mick. Blink
#29 Posted : 03 November 2018 17:48:22
Issue 21
Parts
Left hand inner side member.there is no assembly in this issue Cheers mick. BigGrin
#30 Posted : 03 November 2018 17:52:58
Issue 22
Parts Left upper wishbone
Left lower wishbone
Left suspension upright.
Here we screw the left hand wishbones to the left inner side frame.cheers mick.BigGrin
#31 Posted : 03 November 2018 17:57:27
Issue 23
Parts
Front cross member.
Here we attach the 2 inner side members done in the previous 2 issues to the front member.cheers mick. BigGrin
#32 Posted : 03 November 2018 18:02:19
Issue 24
Parts
Right hand upper brace
Right hand diagonal brace.
Here we just attach the 2 braces supplied in this issue to the previous assembly.cheers mick.BigGrin
#33 Posted : 03 November 2018 18:06:52
Issue 25
Parts
Left hand upper brace
Left hand diagonal brace.
Here we attach the braces as before to the previous assembly.cheers mick.BigGrin
#34 Posted : 03 November 2018 18:13:12
Issue 26
Left hand lower brace
Right hand lower brace
Steering rack mounting bracket
Oil filter
Here we attach the 2 braces provided in this issue to the previous assembly and attach the steering rack mounting bracket. Cheers mick. BigGrin
#35 Posted : 03 November 2018 18:21:02
Issue 27
Parts Right suspension upright
Brake disk
Caliper
Suspension bushes
Shock absorber shroud
Coil spring
Damper body
Pivot pin
First we put the brake caliper over the brake disk then attach the disk to the suspension upright, attach this between the wishbones, then attach the shock absorber assembly . Cheers mick BigGrin
#36 Posted : 03 November 2018 19:04:34
Issue 28
Parts
Brake disk
Caliper
Suspension bushes
Coil spring
Damper body
Pivot pin
This is just a repeat of previous issue just the opposite side.cheers mick.BigGrin
#37 Posted : 03 November 2018 19:09:38
Issue 29
Parts
Sump
Torsion bar assembly
Here I painted the torsion bar black, and attached it to the sump.sorry forgot to take pic of this on its own.cheers mick.BigGrin
#38 Posted : 03 November 2018 19:15:18
Issue 30
Parts
Radiator header tank
Header tank support
Fan motor assembly
Cooling Fan
Hose
Filler cap
Here we assemble the fan and header tank assembly, I repainted the hose rubber black.cheers mick.BigGrin
#39 Posted : 03 November 2018 19:54:51
Issue 31
Parts
Front subframe Base
Front subframe right stay
Front subframe left stay
Here we fix the front subframe to the previous assembly, then attach the left and right stays,one I had to file the corner out for it to fit,then fit the fan and header tank. Cheers mick. Blink
#40 Posted : 03 November 2018 20:07:04
Issue 32
Parts
Steering rack assembly
Steering column assembly
Anti roll bar
Anti roll bar links
Rack mountings
Anti roll bar mountings
Hose
Water pump
First of all we put the 2 links on the anti roll bar, then attach this to the sub frame and fasten this to the wishbones fit 2 clips to hold anti roll bar, add the steering rack mounting, then the braces, add the steering rack system connecting it to subframe and hubs,cheers mick. BigGrin
5 Pages <1234>»
This page was generated in 0.373 seconds.
