9 Pages 123>»
Magpie1832's Tornado Gr.1 "Operation Desert Storm " Options
#1 Posted : 29 October 2018 21:14:28
Here is my Entry into the "Last Year of the Panavia Tornado" competition
I have ordered the 1/32 Gulf war Tornado awaiting delivery. Also i have the White metal undercarriage and the Tornado book.
I have managed to get hold of the Old Flightpath Gr1 set not the conversion set.
Chris
magpie1832 attached the following image(s):
#2 Posted : 29 October 2018 21:33:05
Look forward to seeing your Tonka Chris BigGrin good luck in the comp.
CaptnBirdseye
#3 Posted : 29 October 2018 22:29:54
Rank: Superelite
Looks a very interesting build. Good luck in the competition ThumpUp
Gray
#4 Posted : 29 October 2018 23:12:35
Wow, looks like there`s gonna be more brass than plastic.Blink
Should result in a fine build, just mind your back when you pick it up.LOL
Good luck in the comp.
#5 Posted : 29 October 2018 23:43:01
Very nice Chris, this is going to be a very interesting build to follow.... Good luck with your entry….Cool Cool Cool
#6 Posted : 30 October 2018 00:43:34
Great to see a Gulf War variant in the competition mix; good luck with the entry Cool
#7 Posted : 30 October 2018 08:01:51
BigGrin Some nice stuff there Chris and good luck in the compCool
#8 Posted : 30 October 2018 08:51:31
Lovely kit Chris, good luck in the competition.
#9 Posted : 30 October 2018 16:03:55
Nice looking aftermarket parts you've got, should keep you busy. Good luck with the comp.
Silent_Running
#10 Posted : 30 October 2018 20:59:06
I was thinking the same thing Derek LOL Seriously though thats a great set of aftermarket parts you've got there Chris. About the book, I've noticed some of the other chaps have got this as well, is this the most comprehensive book out there for the Tornado? Have fun with your build. BigGrin
#11 Posted : 30 October 2018 23:10:29
Cheers Guys. Thanks for the encouragement.
The book is probably the best source of info on the Tornado with many pictures and Diagrams. Well worth the buy if you are after doing plenty of detail.
Chris
#12 Posted : 12 November 2018 15:34:03
Quick update, the kit is released and has been dispatched. So hopefully will start her in the next 3 weeks.
Chris
#13 Posted : 23 November 2018 01:05:59
Finally I make a start on my first complex polystyrene Plastic kit with upgrades in over 10 years. So have to re-learn my skills again.
I started with the Ejector seats. Well one of them. It took a-lot of filing the white metal bits to get them to fit but I like the look. Some of the parts were wrong in the set. The Air pipes out of the side of the seat were incorrect, they gave me 4 the same not 2 left and 2 right. So I made my own from wire.
I had a few problems with the superglue not sticking. I made half the seat last night, picked it up and it fell apart. Not good. The brass bits weren't holding also the white metal parts weren't either. I roughed some of the bits up they have held up to now.
I then removed the wiring from the bulkheads and replaced with wire. I installed the pedals with the photo etch plates.
Chris Cool
#14 Posted : 23 November 2018 08:46:22
Nice start Chris, looking good. I’m sure it will all come back to you.Cool
DaDokta
#15 Posted : 23 November 2018 09:19:26
Nice start!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#16 Posted : 23 November 2018 09:36:05
Very nice start Chris, those seats look rather impressive.Cool
#17 Posted : 23 November 2018 11:58:38
Nice start Chris, the seat looks great.
#18 Posted : 23 November 2018 15:13:39
Nice start, good luck with the competition entry Cool
#19 Posted : 23 November 2018 17:20:19
BigGrin Nice start and looking good, by the way most plastic/resin kit parts have a release agent that needs to be washed in warm soapy water to remove it before construction begins its the same with etch parts but they have an oil coating that will need the use of a degreaser so the glue and paint will adhere to themCool
#20 Posted : 24 November 2018 00:26:33
Very nice start Chris, look forward to seeing more.....Cool Cool
9 Pages 123>»
This page was generated in 0.207 seconds.
