issue one bonnet lacks bosses and doesn't fit grille. Options
twswws
#1 Posted : 30 October 2018 15:03:30
Rank: Newbie
just got several parts to attach to the bonnet and find the issue one bonnet totally different to the one shown in the build illustrations. Anyone else found this. On mine the hole for the grille is too narrow and the bosses for the latch are missing along with others.
#2 Posted : 30 October 2018 15:13:22
Is it the bonnet part from the test issues?
If so, you can't use it as it's very different from the actual part released as the kit.
Roy.
twswws
#3 Posted : 30 October 2018 16:50:26
Rank: Newbie
Hi Roy. It may be a test issue. I got about four and then it went wrong and started up again. TW
#4 Posted : 30 October 2018 23:27:24
It’s noted in Jaguar discussion ahead of the release, that test issue parts should not be used as part of the release build, there are changes to the test parts which affect future assembly and appearance if used.
This page was generated in 0.847 seconds.
