Joined: 08/03/2011 Posts: 245 Points: 726 Location: Norwich
Did I miss something as I don’t yet seem to have enough angled plugs for the left & right leg screw holes. Specifically the ones on the Power Packs (box at base??) I have 4 from a previous issue, but we need 8 I am up to issue 93 & still missing 4 Any advice on which issues these should have come in? Thanks Well spin my nipple-nuts & send me to AlaskaCurrent Builds:McLaren MP4-23Finished007's Aston Martin DB5FinishedMillennium FalconR2-D2BTTF Delorean (Maybe)
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,223 Points: 21,976 Location: Northamptonshire, England
These will come in the final issue along with the panel lugs. Regards Mark Regards Markwarren (Mark) Admin
Its been highlighted numerous times..
https://forum.model-spac...spx?g=posts&t=29718
The panel plugs fill the last few screw holes and is best to leave them out until you have tested R2-D2 for the first time, just in case you need to troubleshoot any of the internal connections.
Thanks, I missed that other post Well spin my nipple-nuts & send me to AlaskaCurrent Builds:McLaren MP4-23Finished007's Aston Martin DB5FinishedMillennium FalconR2-D2BTTF Delorean (Maybe)
Joined: 02/01/2017 Posts: 92 Points: 290 Location: Kintbury, West Berkshire
They will be in either issue 94,95,96,97,98,99 or 100 - just a guess!
LSainsbury wrote:They will be in either issue 94,95,96,97,98,99 or 100 - just a guess! Post #2 tells you exactly where...
