5 Pages <12345>
micks E type jag build Options
#41 Posted : 03 November 2018 20:20:24
Issue 33
Parts Radiator front and back.cowl and hose,
Here we fix the water pump and hoses to the front of the engine,I deseamed the rad and repainted it semi gloss black, and picked out the bolts in silver, then painted the hoses rubber black after deseamed them, then fit in the engine, the distributor connectors, the oil filter, then added the Sump to the bottom of the engine. I had to scrape the pins for lighter fit, so it's comes off easier to fit battery's, lost the pics to this stage, but it can be seen in later issues.cheers mick.BigGrin
#42 Posted : 03 November 2018 20:26:54
Issue 34
Parts
Front bulkhead
Here we assemble the radiator,and fit it to the front of the previous assembly and connect the hoses to it,cheers mick. BigGrin
#43 Posted : 03 November 2018 20:53:12
Issue 35
Parts
Reservac tank
Brake servo unit
Fluid reservoirs
Fuel filter
Clip
Brake vacuum hoses
Hydraulic and fuel pipes
Here we fit all the above to the front bulkhead. BigGrin
#44 Posted : 03 November 2018 21:17:19
Issue 36
Parts
Windscreen wiper motor
Engine stabiliser mounting
Throttle linkage
Voltage control unit
Reservoir bracket
Washer reservoir washer cap,heater water control tap, washer tube, heater motor,heater,case all theses parts are fitted to the front bulkhead. Cheers mick.BigGrin
#45 Posted : 03 November 2018 21:23:22
Issue 37
Parts Left hand mudshield, right hand mudshield, battery leads, battery,gearbox mountings here we attach the front bulkhead to the previous assembly. Cheers mick.BigGrin
#46 Posted : 03 November 2018 21:30:21
Issue 38
Parts wheel rim
Inner spokes
Here we attach the battery's leads to battery, then attach this to the left mudshield, then this is attached to the rest of the assembly.BigGrin
#47 Posted : 03 November 2018 21:37:51
Issues 39 to 41 deal with the assembly of a wheel,I just followed spal guide to this,the top one is the spare, with 2 spoke crossover, I'll leave this one like this,the bottom one is 3 spoke crossover which I'll use on the other 3 that go on the car.cheers mick.BigGrin
#48 Posted : 03 November 2018 21:52:29
Issue 42
Parts Front floor assembly
Here there is no assembly in this stage.cheers mick. BigGrin
#49 Posted : 03 November 2018 21:55:42
Issue 43
Parts rear floor assembly
Here we screw the 2 half's of the floor together. Cheers mick.BigGrin
#50 Posted : 03 November 2018 22:04:16
Issue 44
Parts lower casing, Upper casing, right hand rear brake,left hand rear brake,right and left hand universal joints,bonnet catch
Here we assemble the parts in this issue which make up the final drive unit.and attach the bonnet catch. Cheers mick. BigGrin
#51 Posted : 03 November 2018 22:10:09
Issue 45
Parts rear subframe. Handbrake linkage
Here we fit the final drive unit from the last issue into the rear subframe,then fix the handbrake linkage to this. Cheers mick.BigGrin
#52 Posted : 03 November 2018 22:21:08
Issue 46
Parts shock absorber body's, shock absorber pistons,coil springs,hub carrier,left hand wishbone Left hand half Shaft, universal joint,mounting plate,long spindle,medium spindle,short spindle. Here we put together the rear shocks first, I deseamed mine and painted them, then it's fit these into the subframe, fit the universal joint into the half Shaft,then fit this to the final drive unit, then add the wishbone to complete this assembly on this side.cheers mick. Forgot to add put the hub carrier in as well
#53 Posted : 03 November 2018 22:25:56
Issue 47
This is identical to issue 46,just the opposite side. Cheers mick. BigGrin
#54 Posted : 03 November 2018 22:34:24
Issue 48
Parts rear anti roll bar,bracing plate,right and left radius arms,mounting brackets,safety straps,links.
Here we first attach the links to the anti roll bar then attach the radius arms to this,we then fit this assembly to the car bottom,then fit the subframe previously built up to the bottom of car,then fit the bracing plate to subframe.cheers mick. BigGrin
#55 Posted : 03 November 2018 22:39:25
Issue 49
Parts silencer upper and lower half's,
Here we screw the 2 half's of the silencer together, then screw this to underside of car,as as far as got for now,more wheels next,cheers mick.BigGrin
#56 Posted : 03 November 2018 22:50:02
You certainly have made a lot of progress Mick BigGrin nicely done.
#57 Posted : 03 November 2018 22:58:16
Looking good Mick.
Cool Cool Cool
#58 Posted : 04 November 2018 01:17:00
BigGrin Coming along nicely MickCool
#59 Posted : 04 November 2018 14:22:04
Looking good Mick.ThumpUp
#60 Posted : 04 November 2018 16:40:39
Hi thanks to all who looked in and left comments much appreciated.
Issues 50 to 52 is just another wheel, first one took about 4 hrs to do this one an hour,must be getting use to the Lil so an sos now, that's me fully up to date on this,cheers mick.
5 Pages <12345>
This page was generated in 0.381 seconds.
