Dave 71 Options
#1 Posted : 05 November 2018 19:28:38
BigGrin Hi Dave
The kit used to supply rolled brass wire that was used to make the anti mine degausing strip around the the ships hull. those can be used instead of the brass wire and will give a better look.
Dave 71
#2 Posted : 05 November 2018 23:52:14
Thanks, does it fit were the load line is or some were else as I hav,nt a clue.
#3 Posted : 06 November 2018 07:40:40
If you look at your side view plans there is a line above the portholes at the bow which then drops to go between the two rows of portholes. If you follow this line it goes all around the ship. Take a look at my build I replaced my wire with square plastic strip at the time I built it.
Dave 71
#4 Posted : 06 November 2018 08:07:40
Thanks that's a great help.just had a quick look at your pictures . what a model looks great. See what you mean now about the wire. Just finishing off rear port holes then starting on sorting wire out . Again thanks for your help. Dave M
This page was generated in 0.126 seconds.
