Revell 1/6 Ford 427 engine Options
kpnuts
#1 Posted : 15 November 2018 21:20:40
Hi all I've been eagerly awaiting this since I ordered it with my birthday money and it's finally here
It's beautifully packaged, feels like a high quality product.
Nothing is attached to sprues it's all in little bags
The one little gripe I have with it is Revell partly assemble it for you like this for instance
There are a few other parts pre assembled.
Problem is the engine block is cast so I've got to find a way to disassemble it to make the cast effect on the block, as you can see it looks far too shiney and smooth as it is.
The kit looks great, i think they made 4 in this series some are no longer in production but I'm going to try and get the full set (I will have to eBay for the rest)
CaptnBirdseye
#2 Posted : 15 November 2018 21:33:09
Rank: Superelite
Agreed Ken looks a great kit, and I’m sure you’ll enjoy building it ThumpUp
#3 Posted : 15 November 2018 21:36:01
Plasticote do a stone-effect rattle can.
Almost like a fine spray sand.
How about a fine coat of that on the engine block, followed by a satin black afterwards???
kpnuts
#4 Posted : 15 November 2018 21:47:07
I have a method using spray on carpet glue then spraying over that, works quite well, if you want a heavier cast effect you just give more coats of carpet glue.
#5 Posted : 16 November 2018 00:22:20
Nice kit Ken, I look forward to seeing this coming together.
kpnuts
#6 Posted : 19 November 2018 20:38:38
Hi all here is the next update.
The back of the flywheel is full of ejector pin marks
Looks a bit better now
Added the machining detail to the engine casing
Added a bit of the casting texture
#7 Posted : 20 November 2018 01:42:48
Making some great progress Ken BigGrin looking good.
Sticky Wickett
#8 Posted : 20 November 2018 16:27:27
Nice model there Ken. I'm interested to see this come together.
Phil W.
kpnuts
#9 Posted : 22 November 2018 21:17:01
It's a great little kit, wish I had better skills to do it justice.
kpnuts
#10 Posted : 25 November 2018 19:46:48
Another update It's really hard trying to make plastic look like metal, all my usual tricks don't seem to be working, need to try some more washes.
kpnuts
#11 Posted : 25 November 2018 22:56:39
I think I know why I'm struggling with this, I'm used to bikes and I can normally get a realistic finish I a bike engine I've ridden and worked on bike engines all my life and I've never seen a gold bike carb, i think that's what's throwing me.
kpnuts
#12 Posted : 26 November 2018 21:12:11
Hi all I'm happier with the carbs (still maybe need some more colouring but def in the right direction)
kpnuts
#13 Posted : 27 November 2018 22:16:11
Hi all I don't have access to a big American car so have had to loosely, and I mean loosely base this on the biggest car I have access to ( my bosses 340sl merccedes)( would have preferred his rolls royce) I've had to be creative with the measurements and this is very simplified, just a framework tho add suspension struts to and stuff.
It is purely to allow me to add some of the many engine connections a couldn't add with the supplied stand. I may not even use this, but and this is a big but, if it looks ok and I can find plans for it maybe I will try to scratch a full 1/6 car to put it in.
#14 Posted : 27 November 2018 22:19:26
Looking really good but I'd 'cheat' a bit and make the engine bay smaller, to make the engine look bigger !
Roy.
kpnuts
#15 Posted : 01 December 2018 21:20:45
Trouble is roy ive already done it and who knows where it will lead.
Hi all well the engine is nearly complete, I've added a few more details to the engine bay ( these are purely to add interest and not based on any car) as I said I need an engine bay to add the connections to the engine.
#16 Posted : 02 December 2018 00:08:07
Looks great Ken, nice idea to display it in an engine bay.
kpnuts
#17 Posted : 05 December 2018 20:08:36
Hi all well the engine kit is finished, just lots of scratch building to do on the engine bay now.
#18 Posted : 05 December 2018 20:18:16
Looking really good.
I'd add a load of relays, fuse box, wiring and some pipe-work.
Even a few decals.
Roy.
RM1
#19 Posted : 07 December 2018 13:39:33
Only just spotted this one ! very nice job !! looks great.
Malc.
Sticky Wickett
#20 Posted : 07 December 2018 14:02:00
Looking really good Ken. I love the wash effect you added to carbs. They look the business!Cool
Phil W.
This page was generated in 0.459 seconds.
