Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Hi Mr T
I am going to be painting the hull so thats why i added the rudder now.
Hi Jonny
Well mate i know what you mean about the glue fumes, ive been sitting in that room most of the morning and had to have the window right open, only troubly is its a we bit windy up here on the 10th floor.
Well a short break now then back to the deck beams, im almost halfway done with them so ith any luck ill be able to start the planking tomorrow.
Foz
So then In between hospital visits i have been busy today and have mede a little progress. I now have the suport beams for the quarter deck in place.  Will trim the frames and start the plankin tomorrow as i need a break now and some food. But thanks to Darren for the help with the mast holes as the instructions in the mag not that good. See you tomorrow with my updates. regards Foz
Joined: 22/03/2010 Posts: 369 Points: 1,150 Location: Broadstairs
Looking good Foz. Going back to the cannon balls, I coated them with a layer of clear varnish after the initial fixing, just to make sure they are held tight. happy b uilding. TIS
Hi Tis
I put a coat of varnish on to start with. but that dod not hold all the cannon ball in pce so added nother good thick coat after and it dod the trick>
Foz
Well started the quarter deck today and found out that the ugly twist i had earlier is still showing its ugly head with the planking in place.  Well time for a short break then back to it. happy building Foz
She's looking absolutely brilliant Foz...I've just finished putting the cannon together...So, I'm a bit high on super glue fumes at the moment...row-row.row the boat..gently down the stream... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Johnny, dont get to hight and think you can take the vic for a sail On another note i never knew id be doing such fiddly little parts when i started this build, but im getting there.
Well then Have finaly finished the quarter deck planking so here is what she is like before i stained it.  And after.  Allthough i used the same satin as on the upper gun deck it seems to look a bit darker. But i can live with it. Regards Foz
She's coming along leaps and bounds Foz...Brill work mate... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Foz,  the whole build is a credit to you, love the planking-----you should be very proud of yourself MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 15/05/2011 Posts: 43 Points: 119 Location: Southampton
Coming along nicely matey
Joined: 20/04/2010 Posts: 141 Points: 426 Location: Worthing, United Kingdom
Excellent work! Quick question: how do you apply the stain so neatly? Whenever I try (using the Admiralty Walnut wood stain), it always comes out a bit hit and miss.
Amipl
I just use cheap wood stain from Wicos, trhere own brand and use a normal paint brush, but just use it along the same way as the planks laid.
Hope this helps
Foz
Looks great mate, Keep it up.. On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Joined: 20/03/2010 Posts: 498 Points: 1,522 Location: South Wales
Looking brill mate! keep it up!!!! Ship Builds on the go
Yamato - DeAgostini Subscription - Highly Recommend This Model AKAGI - DeAgostini Subscription - Highly Recommend This Model RMS Titanic Lifeboat (Kind Gift from DeAgostini Crew)
Good to see your back on line after the problems with the gallery. I hope things run a little smoother for you from now on.
Thanks for all the kind words lads, its much appreciated. Im now missing the build as im stuck on camp untill Saturday evening so will not get to much done then, but hopefully and update will be on here then. Once again. Thanks lads. regards Foz
Hi fozy where are you,  I have just sent apost to you about cabin Partitions, to somewhere, but this is a different thread, Oh well what do I know MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
LOL MWG
This thread is my build diary.
Foz
 Thanks Fozy, ah well to much wine!!!!!!!!!!!!!!! MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Guest (12)
