Issues out of order??? Options
dino
#1 Posted : 24 November 2018 17:03:58
Rank: Newbie
I just received the latest (for me) set of issues.
It’s the big box with the main body shell. But my packing slip says it should have issues 82,83,84 and 85.
When in fact the box actually hads 85, 86, 87 and 88 in it.
Am I the only one with this box packed incorrectly?
Cheers
Building: E=Type Jaguar
Built: Aston Martin DB5 "007"
Others: Flying Scotsman and Mallard (both intended as retirement pastime builds)
#2 Posted : 24 November 2018 18:48:52
Sounds like it could be a packing error. Contact customer services and they will get it sorted for you.
Okcid
#3 Posted : 19 December 2018 23:54:57
Rank: Newbie
I'm still awaiting issue 74 etype build.
Received 71,72 and 73 with just a biro ed circle around 74 in the accompanied letter.. no explanation !
so stuck until it turns up...anybody else awtg issue #74 ?
#4 Posted : 19 December 2018 23:57:39
Give CS a call, they'll give you an update on your missing issue. Better to call rather than email, by calling you'll get a quicker response....Cool Cool
Okcid
#5 Posted : 23 December 2018 17:40:53
Rank: Newbie
I did do a couple of weeks ago..still awtg #74..Can't believe I'm the only one.
Kind regards.
#6 Posted : 23 December 2018 19:33:16
Kind regards.
You say you called CS a couple of weeks ago but you don't say what their response was. If issue 74 is out of stock then rest assured your missing issue will be sent out as soon as it comes back in stock. I'd give them another call and ask for an update on your missing issue.
alemo
#7 Posted : 31 December 2018 16:30:53
I was waiting for issue 74 and it turned up today along with 82, 83 and 84 it seems that you will always get 4 issues at a time, I guess to make up to the monthly payment or fit administration because some issues appear to be higher value than others.
Alec
Adapt, improvise, overcome.
This page was generated in 1.154 seconds.
