All looking good Mick, great to see you're now up to date.... Regards Alan
Nice work, you are obviously getting to be an expert on these. Mark Regards Markwarren (Mark) Admin
Good stuff Mick. Only problem with catching up is waiting for the next parts. Hope your next parts are due soon. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 09/10/2018 Posts: 3 Points: 9 Location: Italia
mogwai wrote:Hi as regarding the engine painting I just taped off the bits I not want painting. And prepped the rest with bit of wet an dry paper before painting to give a key to the paint,then it was just brush applied with tamiya semi gloss black, then added the gold to the ports, hi Roy I'll be pinching some your ideas as I intend to carpet with dolls house carpet,and will be doing the leather trim to, thanks to all who looked in cheers mick. For the preparation of painting, do you think a chemical paint remover can be used instead of paper?
Hi personally I'd not use it as it may eat away at the plastic and destroy the engine ,cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
mogwai wrote:Hi personally I'd not use it as it may eat away at the plastic and destroy the engine ,cheers mick. Thanks, Mick. So far I have received only the first issue and looking at your photos I was convinced that all the pieces of the engine were made of metal as the cylinder head I already own. Regards Salvatore
Joined: 18/11/2017 Posts: 17 Points: 41 Location: Fleet, UK
Salvatore,
I used a product called Modelstrip which is safe to use on plastic - it is a paste and you put the parts in a sealed bag overnight before washing off with water. I seem to remember that I sprayed the whole block satin black and then masked the area around the copper core plugs using masking tape punched out using an ordinary paper punch. Effect was much better than hand-painting the copper.
When you get to attaching the wheels to the hub, there is an important tip which I would like to share with anyone who is at an early stage like yourself.
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,838 Points: 17,666 Location: ipswich
Looking really good so far. This kit just has SO much scope for upgrades. Have fun with it.
Roy.
Hi that's useful info ,I'm having no issues with attaching wheels ,but any tips would be welcome ,but be best if you put it in the jaguar discussion section ,rather than a individual diary ,more people would find it there ,cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Mogwai,
I found the screws which hold on the wheels were very hard to tighten and, when it came to removing them, the thread had disappeared and the screws were too slack to tighten again! Solution: bought a set of 6BA taps and screws to create a proper thread and now the wheels can be taken off and put back on easily.
Hi good idea ,when I put screws in metal to cut thread I always put drop of oil in hole first ,this helps when cutting the thread ,so it don't tear due to dry cutting ,cut it slowly 2 turns forward one back ,I find this prevents thread stripping and leaves a nice thread in holes ,I have metric taps anyway ,cheers mick . Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Mick, Your solution makes sense - coming from a largely plastic kit background, I have not encountered this problem before! Pity DeAg don't recommend your method in the instructions!
Cheers,
Joined: 28/06/2017 Posts: 10 Points: 20 Location: High Wycombe
Is anyone able to build my wheels for me as I just cant get the hang of it, my patience isnt great, would be a great help please, thanks, paul
Hi Paul happy to help have sent you PM cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Hi there mick, sending pic of wheel over to you, paul
Picture of Jag e-type wheel mick, paul
Hi got few more issues of this now, so gone back a bit, took door apart and covered it suede leather, just like the look of suede, to normal leather, probably never done on a real one, so just personal preference. The door on the right done and the left as supplied. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Nicely done Mick  looks good. Al
Nice work Mick, coming on nicely. Mark Regards Markwarren (Mark) Admin
