Swift 1805 Options
greg
#1 Posted : 28 November 2018 02:13:35
Rank: Amateur Level 1
my past experience has been plastic models. SO why dive into wood modeling ?
Because Im older and wiser..I hope
I appreciate the great packing, all vacuumed in plastic & plenty of bubble wrap in the shipping box.
Everything is on the CD (different experience for me) might be visiting FedEx
I dragged and dropped all file to desk top
Double checked the parts list (better one on the CD)
SO here goes my first wood build
Build Time 30 minutes
Some of those sheets are thin
I cut 1 a&b and 2-10, keel- both sides to make sure I got all of the Tabs
3rd Photo - small parts bin - Thanks again, for the container
sanding and gluing to follow
any step I missed to get the 3rd photo to show?(now removed)
other photos come and go with edits ???
greg attached the following image(s):
NOW - Building SWIFT 1805
long term goal "USS Constitution"
completed "Fair a Frame" by Model Shipways
DaDokta
#2 Posted : 28 November 2018 11:28:49
I will follow this build with great interest!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#3 Posted : 28 November 2018 12:21:33
Hi Greg
Good luck with your venture into wood, I`m sure you`ll enjoy it.BigGrin
The picture issue you mention is an ongoing problem with the forum that is cured simply by refreshing the page (maybe a couple of times). Its a known issue that is being worked on.
Tip: The forum will take pictures up to 650 pixels wide, so you have scope to increase the size of your pics should you wish.
Congrats on your "Blue" medal for starting a build diary and I look forward to more of your work soon.Cool
daffy09
#4 Posted : 28 November 2018 12:32:35
Hi Greg. I think you'll enjoy this venture and I'll be following along with this build diary.
Happy building
David
#5 Posted : 28 November 2018 16:04:00
Looking forward to seeing this progress.
greg
#6 Posted : 29 November 2018 04:32:36
Man almost had a great accident
Gluing number 10 with super glue. I know I placed it correctly, I must have handled the keel roughly. I happened to take another look and it had slipped out. Glue had not totally hardened, like a rookie, I started to pry, thinking I could just sand and and re glue. BUT HEY - lets push it in and hold.
LESSON 1 - One item at a time when dealing with super glue - I cant be trusted
Just for fun I placed the keel in the "Fair A Frame"....ya - not going to work
Build time
40 min
Dry fitted all before the glue fest.
Rest of the gluing went off without a hitch. I checked all the ribs for wobble. Another smaller coat is in order for some, despite the run you see in the photo.
Number 2 was flush on top of the keel, but over hangs at the bottom. Add that to the sanding joy ahead.
I decided to make the ship stand now.
The "Deck" is my first big concern. Sounds like I should glue the middle first, let dry, then Glue to the ribs.
Any advise is appreciated
greg
#7 Posted : 29 November 2018 04:36:08
delboy271155 wrote:
Hi Greg
I made sure to resize first.
Roger that - refresh it is.
many thanks
#8 Posted : 29 November 2018 07:44:24
BigGrin Nice start and looking good
#9 Posted : 29 November 2018 08:51:22
Hi agree, looking good so far. Looking forward to seeing this progress.
#10 Posted : 29 November 2018 09:43:07
Looks like you're off to a good start Greg and I look forward to following your progress.... Keep those pics coming....Cool Cool
greg
#11 Posted : 07 December 2018 19:05:04
in-between overtime
sanding
gluing both part 12's
rechecking that once dried
center-line drawn on deck prior to gluing
I get a kick out of the instructions have you do this after gluing
looking forward to gluing the deck on
until next time
QUESTION
How does make a link into the signature (attached to now building)
thank you in advance
greg
#12 Posted : 14 December 2018 01:13:34
Cursing my first accident Cursing
carrying it back from sanding, caught against the pants AND i hear a crunch as it hits the carpet
so here is my attempt at bracing it...next time, dont carry it so low
#13 Posted : 14 December 2018 09:45:41
Hi Greg, never good when mishaps occur but we've all experienced them at some stage in our modelling journey. Bracing you've done should be fine and will be even stronger once you get some of the planking done....Cool Cool .. Hope now your progress goes mishap free....Cool Cool
greg
#14 Posted : 01 January 2019 07:03:49
still carefully gluing the deck on
other misc work:
filed all the metal parts
worked on the two hatch covers
more photos soon
Happy New Year everyone
daffy09
#15 Posted : 01 January 2019 13:47:28
Happy New Year to you Greg. Looking forward to seeing more pictures of the Swift coming together.
Happy building
David
This page was generated in 1.083 seconds.
