benni, not all pics appearing Options
benni
#1 Posted : 30 November 2018 12:50:44
Rank: Amateur Level 1
I've tried to post my build, but some pictures don't appear??
I've tried more than two or three times yet they don't seem to appear, although the reference to them is on the page?
Can someone please help?Confused
Built: HMS Victory
#2 Posted : 30 November 2018 13:02:54
This is a known problem and being handled by our IT guru's. If you have missing images when visiting a post/topic or after posting then simply refresh the screen a couple of times and the images will appear....
#3 Posted : 30 November 2018 13:18:21
Also, any pics larger than about 140k will not appear anyway.
You will need to reduce any pictures to this size - or a bit less.
Roy.
z8000783
#4 Posted : 30 November 2018 13:26:03
Groups: Unapproved
If you have access to some web/cloud space, you can load your images up there using ftp and then put links to them on the site.
This will be the best solution until the new forum appears. Even after repeated refreshing I cannot seem to get all the images in posts to appear.
This page was generated in 0.095 seconds.
