Bulwark height Options
Foz
#1 Posted : 16 July 2011 20:05:01
Quick qestion regarding the height of the Bulwarlk in issue 56.
It say in the mag to be no higer than 16.5mm. Is this the height just at the fromt or all the way along.
looking at the pic i dded mine is much higher so do i need to sand it down all the way along?
Once again your help is appreciated.
Foz
willie
#2 Posted : 16 July 2011 22:40:31
looking at the rule its looks like you have an extra plank the three bottom planks make your hight eather sand back or remove the top plank,,, looking again is the top plank taperd if so remove and sand back the second top plank to the right size all the way along
#3 Posted : 17 July 2011 00:35:29
just remove the 4th plank,top one.that sould do it.
Tiswas
#4 Posted : 17 July 2011 12:47:02
I agree so far, plus trim back the frames to match the height if the planks.
TIS
This page was generated in 0.032 seconds.
