2 Pages 12>
Waterboy.1 Options
Waterboy.1
#1 Posted : 05 December 2018 16:25:41
I have now completed R2D2 and followed the instructions for activating the battery box so plugging in charger turning on then pressing button 6 on the front, His head turns the front light comes on then he bleeps ready for connection to the app but when I unplug the charger everything goes off! It won't run off the battery box and I'm using genuine sanyo 18650 battery's from Germany don't tell me we all have a battery box issue? I've msged model space and emailed and no reply there's no app and no instructions online if anyone has any info on this to share that would be great 😊
#2 Posted : 05 December 2018 16:48:46
The instructions for activation on page 13, step 12 clearly says to attach the charger switch it on at the mains for a few seconds then to remove the charger from R2-D2 completely before switching him on via the main switch under his base then by pressing the bottom swith of the blue switches on his front panel.
The charger should not be attached to R2-D2 when switching him on for the 1st time.
Waterboy.1
#3 Posted : 05 December 2018 16:54:15
Yes I did that first and nothing happened so I then went on to powering him up while plugged in and that worked but when unplugged it goes off and nothing works
Waterboy.1
#4 Posted : 05 December 2018 16:56:29
The other funny thing is button 6 turns him on but won't turn him off and is clearly labeled ON and OFF
Waterboy.1
#5 Posted : 05 December 2018 16:57:37
Have you completed the build and got it working?
semaj
#6 Posted : 05 December 2018 17:01:14
Out of interest, should the battery activation sequence be carried out with the master power switch (on the base of r2) turned on of off? Or does this not make a difference?
Seeing quite a few on social media having the exact same problems.
Building:
Complete:
Waterboy.1
#7 Posted : 05 December 2018 17:07:06
I think we have duff battery boxes myself
#8 Posted : 05 December 2018 17:07:42
It sounds like you have electrical connection problems so a check of all your conections should be made on R2.
By the way the Guide is now available online. If you click the link below then the build it is ready to download there-
https://www.model-space....he-r2-d2.html?clearcache
Waterboy.1
#9 Posted : 05 December 2018 17:12:29
How's it looking for getting the app?
#10 Posted : 05 December 2018 17:13:39
The instructions on page 13, step 13 indicate that the base power switch is to be turned on only after completing step 12 where the charger is pluged in and unpluged. So the battery activation is carried out with the base switch in the off position.
Michaeljf1980
#11 Posted : 05 December 2018 17:14:11
Rank: Beginner Level 3
Maybe we’ll get the app as a Christmas present, also still waiting for info they said they were going to supply about the batteries, surprise surprise we’re still waiting
Waterboy.1
#12 Posted : 05 December 2018 17:15:54
So if someone switches the power on when plugging the charger in where does that leave them? I tried it the correct way first and got nothing that's why I went onto powering him up with the charger
Waterboy.1
#13 Posted : 05 December 2018 17:18:34
I'm using genuine sanyo 18650 3500mha from germany
Michaeljf1980
#14 Posted : 05 December 2018 17:24:44
Doesn’t it say to use 2600 mah or lower ?
#15 Posted : 05 December 2018 17:30:07
If R2 will not start up in the way described in the instructions then that indicates a bad connection somewhere. You say in post #4
The other funny thing is button 6 turns him on but won't turn him off and is clearly labeled ON and OFF.
That indicates a faulty conection somewhere so you should double check all your connections.
R2 started up in the correct way when I did issue 100.
#16 Posted : 05 December 2018 17:31:15
It says a minimum of 2000mAh and recommends 2600 to 2800 mAh. - the higher the mAh = the longer the run time and the charge time.
semaj
#17 Posted : 05 December 2018 18:10:11
Cool thanks arpurchase. I dont yet have the issue to hand, but have seen images etc. Wanted to be fully clear for when i come to do it myself.
It makes me wonder if people have damaged their unit by trying to turn it on with the power still plugged in, or before they have activated it, by not correctly following the instructions.
Building:
Complete:
Waterboy.1
#18 Posted : 05 December 2018 18:12:40
Button 6 is just a button not a switch so pressing ON should have the same affect as pressing it a 2nd time for off if it was a wiring issue the 1st press wouldn't work surely?
semaj
#19 Posted : 05 December 2018 18:18:27
The online guide says if you press and hold the bottom button on the front panel it will force a shut down. Try this, it may reset the system so to speak?
Building:
Complete:
#20 Posted : 05 December 2018 18:40:27
All 6 of the buttons cover the micro-switch assembly below it so by pressing the button you are activating a micro-swith to its off or on position.
Being unable to switch him off indicates a problem somewhere so by checking the conections it eliminates that as being the problem source. Once that problem is eliminated then we can move on to checking other parts. You could also double check the mounting and operation of the switch assembly to the body to eliminate this as well.
Guest (7)
2 Pages 12>
This page was generated in 3.074 seconds.
