2 Pages <12
Waterboy.1 Options
Waterboy.1
#21 Posted : 05 December 2018 23:23:15
I've found the problem, The button + end of the battery's are not making contact with the battery box so I had to bridge the 0.000001mm with some thick copper wire now he's working a treat😉
#22 Posted : 05 December 2018 23:51:30
Great, glad to hear itBigGrin enjoy putting him through his paces.
semaj
#23 Posted : 05 December 2018 23:55:49
is that really a safe thing to do with high power batteries?
Building:
Complete:
#24 Posted : 06 December 2018 00:03:22
Have to agree, not something I would do with these kind of batteries.... In addition, making these kind of modifications to your R2 could invalidate your warranty should something untoward happen.
#25 Posted : 06 December 2018 00:15:42
That’s dangerous and also suggests you might have an inferior battery type!
You can actually buy battery button top magnets which would be safer as they would remain in place
Waterboy.1
#26 Posted : 06 December 2018 00:41:45
I'm using genuine sanyo/Panasonic 18650 3500mha so there not copy's or cheap to buy
semaj
#27 Posted : 06 December 2018 00:49:00
Some button top cells dont have tall enough buttons but more short nipples. These are no good for what we need, but what the problem is with buying online is that both button and nipple are all sold as the same. These batteries are usually used in high power torches and things with a simple contact at each end. Our battery pack has been designed in such a way to prevent them been fitted the wrong way around, but we need cells with full sized to fit through the slot and reach the contact. You could grind out the bits of plastic at the positive end so the battery will be fully pushed up to the contact by the spring on the negative end. A safer and simpler solution. You would have to be extremely careful in the future replacing them that they are fitted the correct way around.
Building:
Complete:
Waterboy.1
#28 Posted : 06 December 2018 11:22:27
I've ordered some magnetic battery caps to extend the + cap so should be a snug fit
2 Pages <12
This page was generated in 0.414 seconds.
