12 Pages «<23456>»
Lancia Delta Martini WRC 1991 + Lancia Delta Test car 1991 Hachette 1/8 Options
frah2o
#61 Posted : 16 November 2018 11:52:41
Fitting the heat shield exhaust
First whaterinfg test on a gravel tyre
frah2o
#62 Posted : 16 November 2018 11:55:59
For today is all, in the next days I will post the last part of the work and finally I will be aligned to date. Blushing
frah2o
#63 Posted : 06 December 2018 11:53:35
Boyshell is arrived and now started the work on struts and chassis
frah2o
#64 Posted : 06 December 2018 11:54:46
Other work on chassis and rear floor
frah2o
#65 Posted : 06 December 2018 11:55:48
Other work on rear floor and rear panel
frah2o
#66 Posted : 06 December 2018 11:57:14
Some final work on chassis before "to melt" upper and lower chassis
#67 Posted : 06 December 2018 11:58:44
Just mind-boggling.
Keep it coming...
frah2o
#68 Posted : 06 December 2018 11:58:44
Checking and filling work on chassis
frah2o
#69 Posted : 06 December 2018 11:59:57
Another bodyshell check with the new mod chassis
Courtesy of Subito.it
frah2o
#70 Posted : 06 December 2018 12:02:02
New workstation (finally) and first work on ride height for tarmac stage
frah2o
#71 Posted : 06 December 2018 12:03:40
Ride height check with door fitting to have an overall view, and comparison with real car.
courtesy of Ewrc.
frah2o
#72 Posted : 06 December 2018 12:12:16
New work for inner panel of front and rear mudguards
Courtesy of Carrozzeria Ferraresi
frah2o
#73 Posted : 06 December 2018 12:20:26
Shaping work on new inside mudguard panel (front and rear)
frah2o
#74 Posted : 06 December 2018 12:47:22
Some details and work on front bumper reshaping due to overheating turbo and intercooler on wrc car.
Tratto da video Abarth Magic
frah2o
#75 Posted : 06 December 2018 12:49:09
Some adjustment work on bonnet to check the right allignment of bonnet with fenders
frah2o
#76 Posted : 06 December 2018 12:50:35
Some work for light led relocation to have the right clearence to fix the mod airbox.
frah2o
#77 Posted : 06 December 2018 12:52:07
Some detail work on headlight cover, an self made reservoir tank for oil vapour
frah2o
#78 Posted : 06 December 2018 12:53:10
Total remade of drive shaft. The hachette is completlely wrong.
Courtesy of Mecatino ricambi lancia
frah2o
#79 Posted : 06 December 2018 12:54:41
Same chassis modify job on second delta, ans test wheatering work on a spare bonnet.
Courtesy of Ewrc
frah2o
#80 Posted : 06 December 2018 12:55:56
Some work on DOT oil brake reservoir. The tank are filled with real dot4
Guest (9)
12 Pages «<23456>»
This page was generated in 0.283 seconds.
