Almost there! What a great build!Greetings, Walter
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,273 Points: 22,126 Location: Northamptonshire, England
Looking excellent, a fine example of this kit Matk Regards Markwarren (Mark) Admin
Hello Guys, After being quiet (but still working on the ship) here is another update of my progress. Issue 120 started:- pennant and sign flags fitted Various issues:- pinnace frame assembled and planked - barge frame assembled and planked - boats removed from building jig, gaps filled with wood filler, then sanded smooth - keels fitted - all three boats painted inside - floor boards cut to size, painted and fitted - gratings cut to size, sprayed black and fitted - thwart support rails added to pinnace and cutter - inside of the top plank painted white on the barge gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Looks great, the end is definitely in sight..... Regards Alan
All looking great!Greetings, Walter
Hello Guys, Thanks for the good comments. Various issues:- enforcing planking added to the gunwales - notches filed to the boats as rowlocks - bottom of the boats painted white - upper rows painted yellow ochre on cutter and pinnace Then came the trouble...I don't know what have I done wrong, but when I removed the masking tape it peeled off the white paint from the hull  ... I used the same masking tape I used earlier, never happened this before... maybe I sanded the hull too smooth, hence the paint didn't stick to it... - I removed the flaking paint and masked the hull for the black and green stripes. Of course, same thing happened after I removed these masking tape too...  - I didn't see the point to use the masking tape again, because I was sure, that it will keep peeling off the paint. So I ended up painting the keels and correcting the missing white paint with free hand. Definitely this isn't a job to someone with shaky hands. Anyhow, I managed to correct the trouble and paint the keels without any noticeable error. - thwarts and seats cut to size, painted and fitted to all three boats. - barrel and bucket painted and fitted to launch - three rudders assembled and started to paint - oars sprayed with primer, started to paint with white gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Very nice work on the ships boats, they all look good.... Regards Alan
Hello Guys, I proudly announce that the ship is now COMPLETED. Last steps were: - painting the oars and rudders - fitting the boats to the deck - applying the 'Victory' name to the stern Net build time: approx. 2500 hours Gross build time: 8 years, mainly in 2017-18 Thanks to all who followed my build diary. My wife is very pleased that after one year she got the dining table back. MERRY CHRISTMAS EVERYONE!!! I'll now start working on the display cabinet and will keep posting updates about the progress. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
I think you should feel extremely proud of what you've achieved with this build, she looks fabulous so congratulations on finishing her and very well done.... Would suggest you post some pics up in the 'Finished Build Gallery' area of the forum and earn yourself a Red Medal in the process..... Regards Alan
Very well done, looks great and a lovely display model
Any thoughts on the next build?
Tomick wrote:Very well done, looks great and a lovely display model
Hi Tomick, Thanks. I always wanted to build a wooden ship but I don’t think that there will be a next one. I think I’m a one-time-builder because I don’t have a permanent model shop to keep building, also I don’t have the space to store the finished models. This ship will take the only available space in our house. This build required to occupy the dining table for a year, I don’t think my wife will let me do it again.  The only thing which can happen is the Victory cross section, because it might fit inside the ship’s display cabinet and I think they would look great together, but is still under concideration. Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Gandale wrote:I think you should feel extremely proud of what you've achieved with this build, she looks fabulous so congratulations on finishing her and very well done.... Would suggest you post some pics up in the 'Finished Build Gallery' area of the forum and earn yourself a Red Medal in the process..... Regards Alan Hi Alan, Thanks for the nice words, also for the hint for the finished build galleries, I posted it there too. Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Hello All, As I mentioned, I'll keep posting progress about the build of my display cabinet. Although it's not a model, hopefully the admins won't have any issues with posting them here, as it's related to my Victory build. As a first step, I cut the 20x20 aluminium profiles to size and assembled. It will be the frame for the base. Initially I wanted the base as a one solid sheet of wood, but I found it being way too heavy, hence the use of the profiles. After assembly I hung it up with nylon ropes (as intended in the final design) and concept is ready for load test, as a first step mainly for the ropes. Total load of approx 45kgs placed on frame, the load represents the weight of the glass panels. The ropes look OK (well, hope so, as they specified for 150kgs), however on the profiles I might need to go for one size bigger (30x30) because the long ones bend approx 6-8mm in the middle  Anyhow, as currently the ropes are the subject of the test, it doesn't really matter if the frame slightly bent. I'll leave it hanging for a while... Obviously, I would be devastated if the cabinet would fall down... of course mainly for Health&Safety reasons but I also would be heartbroken for the ship. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Hello All, First, let me wish a late happy new year to all, I've been busy with my display cabinet lift mechanism. - Gear box parts were machined (CNC) from aluminium. - Vertical support brackets precisely drilled on CNC. - All parts assembled. End result is pretty much the same as on the plan.  1st no load functional test performed... Passed... motor shaft actually driven by a battery screwdriver, but proves that the mechanics works seamlessly, four sliders (guide the rope for even winding) moves nicely. You can check a video about trial on my public facebook album: https://www.facebook.com/laszlo.for/posts/2293533973990756gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Joined: 29/12/2018 Posts: 223 Points: 671 Location: Lancashire
Morning... Im going to steal one of your ideas if you dont mind  . Standing the boats oars in oasis and paint them.... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Ant62 wrote:Morning... Im going to steal one of your ideas if you dont mind  . Standing the boats oars in oasis and paint them.... Hi, Don’t worry the use any of the ideas, that’s why this forum is here. Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Must say Laszlo mate its a lovely build of the victory. Impressed.. Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Joined: 10/03/2016 Posts: 74 Points: 225 Location: Mirfield West Yorkshire
Wow. Fantastic work well done,I hope my build turns out half as good as yours ..
 Your Victory build looks fantastic Very well done. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Guest (22)
