Hi guys - I've got a problem with my R2D2. It wont start up  . On power up it moves forward slightly but that's it. LED on front is RED and head does not move. Batteries are fully charged, in the correct way and after initialisation there is 12.5V on the main output, before initialisation 0V (black plug). Possibly related it does not sense that it is being charged, charger does charge the batteries but the indicator LED just stays red. I've checked all the wiring and cant see any missing, in the wrong ports or inserted incorrectly. Help!!
Checkout the R2 troubleshooting guide, the link is below. https://forum.model-space.co.uk/...aspx?g=posts&t=30247Regards Mark Regards Markwarren (Mark) Admin
Hi steve Can you check your battery's are making full contact at both ends in the battery box. Thanks Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Also, are your batteries proper 'button top', can you post a photo of the button top end?
 Rank: Pro Groups: Registered
Joined: 20/12/2016 Posts: 138 Points: 414 Location: Plant City, FL
forum admins: i posted a thread asking if the guide can get a list of the r2 init steps to help us work out what issues we have.
but so far no reply on that.
the trouble shooting post is where it goes but i was not able to post on that topic i guess it's locked.
if we know the order and we see some things happen and then it stops then we can compare that to the list and narrow down what the fault might be. for example left leg then right leg or right leg then left leg ??
figuerres wrote:forum admins: i posted a thread asking if the guide can get a list of the r2 init steps to help us work out what issues we have.
No response to it because at the moment we are concentrating on resolving individual problems as being the priority to resolve. That’s not to say it won’t be done, just that there are other priorities right now.
Tomick wrote:figuerres wrote:forum admins: i posted a thread asking if the guide can get a list of the r2 init steps to help us work out what issues we have.
No response to it because at the moment we are concentrating on resolving individual problems as being the priority to resolve. That’s not to say it won’t be done, just that there are other priorities right now. i understand that, just that my post had no reply at all so i did not know if it had even been read by any of the admins. a simple "Got it" would have let me know.
Joined: 10/12/2018 Posts: 70 Points: 225 Location: London
StevePB wrote:Hi guys - I've got a problem with my R2D2. It wont start up  . On power up it moves forward slightly but that's it. LED on front is RED and head does not move. Batteries are fully charged, in the correct way and after initialisation there is 12.5V on the main output, before initialisation 0V (black plug). Possibly related it does not sense that it is being charged, charger does charge the batteries but the indicator LED just stays red. I've checked all the wiring and cant see any missing, in the wrong ports or inserted incorrectly. Help!! I have exactly the same problem!!!!!!!!!!!! and i have checked everything, of course the next question is what is your batteries continuous discharge rate?
Hi Peter can you check with a test meter [if you have one]if you are getting power from the battery box by testing the power lead from the battery box. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote:Hi steve
Thanks
Andy They are, voltages all check out also.
arpurchase wrote:Hi Peter can you check with a test meter [if you have one]if you are getting power from the battery box by testing the power lead from the battery box. Is that with the battery box connected or not?
I'm suspecting my batteries as they have a low continuous discharge rate if not them then it's the MCU!!!!!!!!!!!!!
Tomick wrote:Also, are your batteries proper 'button top', can you post a photo of the button top end? Yes they are - image attached of batteries from seller and installed correctly in battery box. StevePB attached the following image(s):
PeterP wrote:StevePB wrote:Hi guys - I've got a problem with my R2D2. It wont start up  . On power up it moves forward slightly but that's it. LED on front is RED and head does not move. Batteries are fully charged, in the correct way and after initialisation there is 12.5V on the main output, before initialisation 0V (black plug). Possibly related it does not sense that it is being charged, charger does charge the batteries but the indicator LED just stays red. I've checked all the wiring and cant see any missing, in the wrong ports or inserted incorrectly. Help!! I have exactly the same problem!!!!!!!!!!!! and i have checked everything, of course the next question is what is your batteries continuous discharge rate? High discharge type for me 30A !! - As for problem it not sensing charging points to either battery box itself or MCU :(
StevePB wrote:PeterP wrote:StevePB wrote:Hi guys - I've got a problem with my R2D2. It wont start up  . On power up it moves forward slightly but that's it. LED on front is RED and head does not move. Batteries are fully charged, in the correct way and after initialisation there is 12.5V on the main output, before initialisation 0V (black plug). Possibly related it does not sense that it is being charged, charger does charge the batteries but the indicator LED just stays red. I've checked all the wiring and cant see any missing, in the wrong ports or inserted incorrectly. Help!! I have exactly the same problem!!!!!!!!!!!! and i have checked everything, of course the next question is what is your batteries continuous discharge rate? High discharge type for me 30A !! - As for problem it not sensing charging points to either battery box itself or MCU :( Well your batteries look good  it's hard to think of what else it could be other that the MCU
arpurchase wrote:Hi Peter can you check with a test meter [if you have one]if you are getting power from the battery box by testing the power lead from the battery box. Do the test with the batterys in the battery box but taken out of R2 so your testing the contacts that go into R2'S black box. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
StevePB wrote:PeterP wrote:StevePB wrote:Hi guys - I've got a problem with my R2D2. It wont start up  . On power up it moves forward slightly but that's it. LED on front is RED and head does not move. Batteries are fully charged, in the correct way and after initialisation there is 12.5V on the main output, before initialisation 0V (black plug). Possibly related it does not sense that it is being charged, charger does charge the batteries but the indicator LED just stays red. I've checked all the wiring and cant see any missing, in the wrong ports or inserted incorrectly. Help!! I have exactly the same problem!!!!!!!!!!!! and i have checked everything, of course the next question is what is your batteries continuous discharge rate? High discharge type for me 30A !! - As for problem it not sensing charging points to either battery box itself or MCU :( Can you also double check all your leads are labeled and places correctly as per the instructions and that all pins are straight where the conectors go in. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote:arpurchase wrote:Hi Peter can you check with a test meter [if you have one]if you are getting power from the battery box by testing the power lead from the battery box. Do the test with the batterys in the battery box but taken out of R2 so your testing the contacts that go into R2'S black box. 12.29v on the black plug
PeterP wrote:arpurchase wrote:arpurchase wrote:Hi Peter can you check with a test meter [if you have one]if you are getting power from the battery box by testing the power lead from the battery box. Do the test with the batterys in the battery box but taken out of R2 so your testing the contacts that go into R2'S black box. 12.29v on the black plug The battery box looks ok. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote:PeterP wrote:arpurchase wrote:arpurchase wrote:Hi Peter can you check with a test meter [if you have one]if you are getting power from the battery box by testing the power lead from the battery box. Do the test with the batterys in the battery box but taken out of R2 so your testing the contacts that go into R2'S black box. 12.29v on the black plug The battery box looks ok. What i'm not sure of is when I check the batteries individually they are all about 4.11v each which means there is about 24v going into the battery box but only 12.29v coming out?
