80 Pages «<2728293031>»
CaptnBirdseye
#561 Posted : 07 December 2018 12:59:46
Rank: Superelite
There really is some fine detail going into this build. It's a pleasure to watch ThumpUp
Regards Gray
Sticky Wickett
#562 Posted : 07 December 2018 13:34:09
pemberg wrote:
Nice work with the handrails and brackets - looks very effective.
Thank you Graeme.Cool Fiddly work but I think it carries the look well.
Phil W.
Sticky Wickett
#563 Posted : 07 December 2018 13:34:53
Regards Gray
Thank you very much Gray!Cool BigGrin I'm glad you're enjoying the process!
Phil W.
#564 Posted : 07 December 2018 14:07:59
Another complex step done beautifully, looks superb....Drool Drool
Sticky Wickett
#565 Posted : 07 December 2018 14:14:47
Thank you very much Alan. Your comments are always appreciated!BigGrin Next up will be grab handles, guard rails, steps and ladders.
Phil W.
DaDokta
#566 Posted : 10 December 2018 07:53:53
Great work and stunning attention to detail as always!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Sticky Wickett
#567 Posted : 11 December 2018 09:00:28
Thank you Walter!BigGrin Fiddly work but it's starting to take shape.
Phil W.
Sticky Wickett
#568 Posted : 13 December 2018 09:15:35
Good morning from 'The Dockyard'.
Just a short update this week which sees the addition of two step ladders to the rear of the lower deck of my 1/48 scale modified conning tower.
I initially thought making these would be a '5 min job'LOL, but due to the fact that they were small and fiddly, i ended up restarting after the first attempt. While building the Mk2 version I had to remedy the odd breakage or two during construction, meaning that these step ladders actually took me three evenings to get right.
I used 1.0mm square plastic strip for the uprights and 1.0mm diameter round rod for the rungs. As I wanted them to sit vertically, I had to spend a bit of time filing and trimming the bottom supports of the step ladders to accommodate the tapered profile of the lower deck sides.
The step ladders are 20mm long and 6mm wide.
The attached photo shows both ladders prior to fitting.
Sticky Wickett
#569 Posted : 13 December 2018 09:17:15
You can just make out in the attached photo the difference in length between the longer supports of both step ladders which fit against the tapered lower deck.
Sticky Wickett
#570 Posted : 13 December 2018 09:18:16
Both ladders turned around to show the other side.
Sticky Wickett
#571 Posted : 13 December 2018 09:19:09
The first step ladder fitted to the starboard side of the conning tower lower deck.
Sticky Wickett
#572 Posted : 13 December 2018 09:19:55
The second step ladder fitted to the port side of the conning tower lower deck.
Sticky Wickett
#573 Posted : 13 December 2018 09:20:47
A view from above showing both ladders attached.
Sticky Wickett
#574 Posted : 13 December 2018 09:23:41
Well that concludes this weeks very short update, so i'd better crack on with the Christmas shopping!CryingLOL
Thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin
Phil W.
#575 Posted : 13 December 2018 16:11:12
Looking good as always Phil, nice work
Sticky Wickett
#576 Posted : 13 December 2018 16:15:03
Thank you very much Graeme!BigGrin
Phil W.
#577 Posted : 13 December 2018 18:53:08
More great progress Phil... onwards and upwards.....Drool Drool
Sticky Wickett
#578 Posted : 13 December 2018 23:41:22
Thank you very much Alan!BigGrin It's slowly starting to take shape.
Phil W.
greg
#579 Posted : 14 December 2018 01:27:21
Rank: Amateur Level 1
what you going to do to the figures ? lol
excellent bashing
NOW - Building SWIFT 1805
long term goal "USS Constitution"
completed "Fair a Frame" by Model Shipways
#580 Posted : 14 December 2018 10:54:06
Excellent work Phil, just watch out for the snakes.LOL
This page was generated in 1.327 seconds.
