Joined: 26/04/2010 Posts: 5 Points: -5 Location: nottm
Hi,i am new to all this so could anyone tell me if the wood stock of the anchor was painted same as cannons in yellow ochre,Thanks.
The anchore is actualy two different blacks. The timber parts are a flat dull black and the iron a slightly more satin finish. If you look for admiral paints on the internet they have a metal black and flat black that are perfect. see my anchor build in 'first wooden ship build' “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Rank: Pro Groups: Registered
Joined: 08/02/2015 Posts: 426 Points: 1,259 Location: Louisiana
sorry to barge in Jase but I thought the timber on the anchors where a varnish brown or something also would you know the size of the hole on the metal part because the manufacture did not punch out the hole all the way there is a tiny piece of metal protuding out of the other side and would like to drill out the hole correctly thank you Ronald
yep you're right I went to look for my self before you replied thank you but I still need to know the size of the hole for ring Ronald
Joined: 10/10/2010 Posts: 691 Points: 2,136 Location: Dorset
Here is a picture I took of the Victory when I was in Portsmouth showing the Anchors Hope this will help GilShapley attached the following image(s): Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
 Hi Ronald if you measure the ring that goes through the hole the hole just needs to be slightly bigger. Start with a small drill and slowly get bigger while checking the fit . Hope this helps Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Since we are on the subject of anchors I was wondering would it be acturate and ok if I put two bands on the loose ends of the moreing lines I saw someone do it on a victory build post thank you Ronald
ronald305 wrote: Since we are on the subject of anchors I was wondering would it be acturate and ok if I put two bands on the loose ends of the moreing lines I saw someone do it on a victory build post thank you Ronald Down to your own personal choice on this one Ronald..... Regards Alan
ok cool thanks Alan Ronald
