Joined: 08/12/2018 Posts: 17 Points: 53 Location: Ireland
My back led only shows yellow not showing green, even though the green was working on test during build. When I go to local wifi I never can get the green light to go on. Any thoughts guys.
The yellow light on the back means you are in Direct WiFi, green light denotes you are in local WiFi. The different colours are so you know what mode you are in. To change it from direct to local press button 5. Just check that you are in the local mode and not direct. Regards Markwarren (Mark) Admin
It lights yellow when IAM in direct wifi but when I go to local wifi I get no green light.
Re-test the rear LED like you did in the test if it all works ok then recheck all your connections are good and retry. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Already checked that yesterday sorry I shudder of mentioned that.
Check the head circuit board for cracks and then check the connections from the board to the main board. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Checked all connections no probs power going to all, no cracks in any of the boards.
Could you check that the micro switches on R2's front panel are all working correctly.You should get a small click when pressed. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Yes they are all working I checked them yesterday.
I also removed the back led today to double check for the green light as re the test during the build and it showed up green. TBH I don't know what's causing this.
There is a bad connection somewhere have you checked the pins are all straight in the sockets from the two cables that go from the head to the body sockets. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Yeah that was the 2nd thing I checked tbh. Deffinatly a bad contact somewhere that's for sure. Time for R2D2 to have his 2nd operation 😂😂
Make sure all the wires are seated correctly in the connectors too as this could be a cause of a bad connection. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
I will indeed thank you for your help. Other than this he is working great really happy with the little fella.
Your welcome Bren, nice to have a thank you too and much appreciated. Please dont hesitate to ask again if you are still having problems with the little tyke. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
No problem thank you again he is all sorted it was one of the wires was the slightest bit loose and not making correct contact all gud now just putting his back on as I write this. Thanks again. It's all bells and whistles from here 😂😂
Indeed now will it be camper van T600 Terminator or the X Wing mmmm decisions decisions 😊😂
 If your into ships the 'Standart' could be an option too Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Great to hear you've now got the little fella up and working Bren and am sure you'll have lots of fun with him.... well done... Regards Alan
