Nog113 Options
Nog113
#1 Posted : 16 December 2018 18:09:46
Rank: Newbie
Hi anyone else have a similar problem I've completed the model but the lightsabre eject mechanism only opens it won't close. The connections seem to be good (it worked at the test stage) and I removed the unit and opened it up to make sure that nothing was catching but it still persists. Only thging I did notice was a slight grinding sound after rdd2 boots up don't know if this is normal or it's the nylon gears in the tube.
Any suggestions gratefully received
#2 Posted : 16 December 2018 18:13:26
You might want to check the gears run smooth and that they have not misaligned.
Nog113
#3 Posted : 16 December 2018 19:10:57
Rank: Newbie
Hi thanks for responding.
I did think that but it looked ok when I opened it up and put the base back to the bottom of the tube. It ejects ok but won't retract and I've checked it's not obstructed.
#4 Posted : 16 December 2018 19:33:47
Hi are the micro switches working and is it traveling all the way to hit the upper micro switch
Nog113
#5 Posted : 17 December 2018 17:19:13
Rank: Newbie
I assume that they are as I tested it as per issue 53 and it worked fine then.
Can't test it again as the test cables were installed when it was complete.
#6 Posted : 17 December 2018 20:04:39
Order a replacement motor from C/S
This page was generated in 0.177 seconds.
