Help please Options
doremi495
#1 Posted : 18 July 2011 15:16:32
Can anybody please tell me the best way to get a curve out of a length of dowel. Thanks in advance.
Dave H
Current builds :- Hachette 1/16 Tiger Tank
H.M.S Victory, Santisima Trinidad (Section), 1/8 scale Aston Martin DB5, 1/8 scale McLaren, YNWA
Lonestar Spirit
#2 Posted : 18 July 2011 16:53:05
Try heating it up with a heat gun, then while hot, roll the doweling as even as possible on a flat surface, it worked for mine a few years back, but now I just replace the doweling, much easier than trying to straighten it!
Not sure it will help, but I hope you get it sorted!
All the best
David
Ship Builds on the go
doremi495
#3 Posted : 18 July 2011 20:26:03
Thanks David. The piece that is curved is walnut and if I can't cure the curve I'm going to have to replace the whole mast.
I'll give your method a go anyway. Thanks again.
Dave H
#4 Posted : 18 July 2011 20:45:38
if that dosn't work,this is a bit more work,have a flat piece of wood with a slot cut down the middle just less then the diameter of the mast,then clamp it to the plank resting in the slot,then spray it with warm water,and leave to dry.it should dry straight.
doremi495
#5 Posted : 18 July 2011 20:57:57
Thanks Karl. I'll get back to you and David when I've sorted the problem. Thanks again.
Dave H
#6 Posted : 18 July 2011 20:59:34
I agree with Karl on that one...Blink
#7 Posted : 18 July 2011 21:16:05
Here Here!!!!!!!!!!!!!!!LOL LOL
This page was generated in 0.046 seconds.
