Joined: 19/12/2018 Posts: 4 Points: 12 Location: United Kingdom
Hi all
Have had an awesome time reading your posts, following your progress and of course building the little guy.
With the app loaded, batteries primed, and a faultless start-up, my first play around was perfect - in both manual and video mode. Since then however, every time i fire him up he gets completely startled.
The patrol mode is going on/off/on/off/on/off causing him to start/stop continuously over-riding any controls i make. His sensors don't sense walls when he's in this state (they do when he isn't in this state) and I'm not sure what to do. I've re-installed the app but that didn't help.
Could button 1 on his torso have a dodgy connection or does it sound like something else does anyone know? Any suggestions most gratefully received.
Thanks all
I think that during running a cable has worked loose somewhere so you need to check there all fully seated and also make sure there is plenty of slack between the head to body main cables. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote:I think that during running a cable has worked loose somewhere so you need to check there all fully seated and also make sure there is plenty of slack between the head to body main cables. Wow. Thank you for such a swift response! I shall certainly try that (probably the weekend now). Thank you very much for coming back to me. I shall post how i get on! Best wishes
arpurchase wrote:I think that during running a cable has worked loose somewhere so you need to check there all fully seated and also make sure there is plenty of slack between the head to body main cables. Thank you, thank you, thank you! It seems that was the issue, and he is working perfectly! I'm so happy! I've attached a pic - mine has been in the wars! Thanks again Happy R2-ing, and Happy Christmas everyone!
Glad to hear he is all sorted again, and he look absolutely fab, great weathering. Happy Christmas. Mark Regards Markwarren (Mark) Admin
He looks great. Merry Christmas and hope you have lots of fun!
Looks amazing and great to hear he is giving you so much pleasure.....  .. Well done on your build.... Regards Alan
Thanks guys.
All the very best.
