Hi all,
I am haveing real problems with the light sabre tube.
Basically is will not work when connected to the main body of R2 it works when connected to the test board.
I have tried the following:
Took all wires out of both main boards and retried my own way as the “official” way is a complete mess!
Light sabre still not working.
Have taken the head off and checked all connections and all seems fine.
Reconnected working a number of times ensuring they are seated correctly and correct way round.
Head removed and connected to main unit while head used screwdriver to activate head sensor to:complete startup process tried again still not working.
Please see attached videos and photos.
Any help is greatly appreciated.
Hi can you examine the circuit board that the projector plug is fitted too for damage or cracks. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi, I have had a look and cannot see any obvious damage. I have photos and videos of this buy cannot attach them for some reason.
Joined: 05/03/2017 Posts: 531 Points: 1,710 Location: Midlands, UK
Photos need to be quite small in size, videos, upload to youtube and share the link Building: Ghostbusters Ecto-1, Ford GT40, Gone in 60 seconds Eleanor mustang, Shelby Cobra Complete: R2D2, Red Bull RB7 RC, Battleship Bismarck, Shelby GT500 'super snake'
Have you removed the board and checked underneath it. Resize your pics to 600 x 450 pixels and they will show on the forum. Video's need to be put on Youtube and a link to the vid placed on the forum. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi, PCB seems ok. Have attached picture and links to videos 👍 https://youtu.be/SeDmKRihgtA
https://youtu.be/6yEF1nIjuDI
Can you check the micro switch is working properly on the front panel . Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi,
When impress the button on the front R2 will beep as with the arms in and out button so think it’s working but no motor movement.
Could you try re-installing the switch unit and double check the wires are all sound unfrayed and unbroken. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 14/02/2017 Posts: 14 Points: 45 Location: United Kingdom
Unfortunately mine is doing this too. Have you managed to resolve yours?
Can you also try some of the above checks as well please Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi,
Will try this tomorrow morning and update👍
Fingers crossed 🤞
Not resolved as yet.
not as yet will try the switch cable in the morning and update.
Hmmm, actually seemed to of got mine working by fiddling with the little silver motor on the side of the lightsabre tube. Hope that works for you. Hope it lasts too!
Hi,
My one works if i use the test board but won’t work when connected to the main unit.
Weird! 😞
qwertyui0p wrote:Hi,
Weird! 😞 Are you getting it to work with switch or the App? Regards Markwarren (Mark) Admin
Hi,
Cannot try the app as waiting for IOS version.
UPDATE:
I have looked at the cable going from the buttons to main pcb and they look ok.
When the button is pressed R2 makes a sound indicating the button press and the arms work ok.
I have removed the cable going from the main pcb to the head and did a continuity test with a multimeter and all are ok.
Does anyone know how to check if the signal from the button press is goi;go to the PCB in the head where the lightsabre motor plugs in?
I have very little knowledge on testing electronics so any help would be appreciated.
