I finished my R2 today and all works great. Got him working on both wifi and direct with no issues and all systems are a go. Only one small issue I need to sort and that to raise the font leg wheel a bit as it keeps catching the front of the foot in the carpet, but that's no big deal as I'll just add some washers to rise it. But all in all I've enjoyed building this little fella. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits. Dry dock no room to display:-. Bismarck, U96. To build:-. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
 well done and great to see another R2 up and running Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice one, great to see another R2 roaming around. Mark Regards Markwarren (Mark) Admin
Great job, good to see another R2 alive and kicking.
Well done Mustang WTG. Enjoy Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Pictures?Pictures? Pictures? Seriously congrats on your completed build! Enjoy Regards Gray
Good to hear your R2 is complete and fully operational, very well done.... Regards Alan
Great to hear of another successful R2 build  well done. Al
Congrat’s on completing your build, time to have fun
Joined: 13/01/2017 Posts: 49 Points: 156 Location: Tewkesbury
Mustang wrote: Only one small issue I need to sort and that to raise the font leg wheel a bit as it keeps catching the front of the foot in the carpet, but that's no big deal as I'll just add some washers to rise it.
I have done this with the supplied extra washers, just undo the 4 screws for the center foot, then undo the caster wheel nut & remove caster wheel ass'y. add 2 washers to the caster wheel and put back in - the caster wheel is no longer retained by the bigger housing hex, so when you add the washer, spring washer & nut on the other side do make sure you tighten fully & it's not just spinning the ball bearings Have fun, enjoy!
