his head moves really quickly on power up and when used in manual mode also he doesn't shake his head. is this an MCU issue, or something wrong with the sensors. can I get a new MCU from deag to try?
Check the sensors and cables first, it is most likely a loose connection or bent pin somewhere. Regards Markwarren (Mark) Admin
I have the same issue sensors all fine arpurchase asked me to call c/s and order a new MCU been on hold for ever
checked all the connections, seem fine. he also doesnt auto center. ordered a new mcu last week
Hi Could you provide a link to the batterys your using on your R2 please. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
man, questioning the batteries again ? lets get straight if there is power there is power, there is a head issue, why can you not just try and help resolve it, if you want I can being mine to you in Dudley @arpurchase and you can check it over yourself ?
NeoFuture wrote:man, questioning the batteries again ? lets get straight if there is power there is power, there is a head issue, why can you not just try and help resolve it, if you want I can being mine to you in Dudley @arpurchase and you can check it over yourself ? It’s a methodical approach to check the basics first, such as having installed adequate batteries. The simple reason being that many have installed inadequate batteries which in itself is going to cause problems and means this has to be checked and resolved first!
Having power does not necessarily mean that the batteries are not at fault. There are numerous fakes on sale and types that are not true button tops or having adequate amperage, let alone having installed Protected batteries., evidence of which can be seen in R2 discussions.
I might remind you that Forum Membership is granted on the basis that you will be polite at all times, respect each other’s views and must abide by our rules which can be found here: https://forum.model-spac...aspx?g=posts&t=4192
Following your comments, I’d be surprised if arpurchase would invite you to his home
