5 Pages «<2345>
HK Models 1/32 Avro Lancaster B1 Mk.1 Options
Kev the Modeller
#61 Posted : 27 December 2018 13:00:50
Don't think I'd be happy either for that price, definitely overpriced and I agree with the reviewer, should not be more than around the £250 mark. I was shocked after watching his review in the second link that the kit doesn't even come with decals for the instrument panels - that's outrageous! I would have expected a sheet of PE panels and acetate gauges for that price and how many ejector pin marks are there in that bomb bay - unbelievably bad!
I bet Peter Jackson of 'Wingnut Wings' will be loving it if he's seen that review. It seems to me that HKM have spent an awful long time trying to get this right …. and then didn't!! Blink Huh ThumbDown
Per Ardua Ad Astra
#62 Posted : 27 December 2018 13:11:13
Did you also note the mention of numerous included parts not being noted in the instructions for placement and the engines seem bereft of detail and having the Radiators of a Mk.II than a Mk.I - The Mk.II was the only version of the Lancaster not to be powered by RR Merlin engines. Instead, it used Bristol Hercules radial air cooled engines.
To say this kit has been 4-5yrs in development, it certainly has a few hiccups..
Kev the Modeller
#63 Posted : 27 December 2018 13:21:46
Did you also note the mention of numerous included parts not being noted in the instructions for placement Confused
Yes Tom, I did, that is really bad for a kit of this price and something I would expect from a short-run company. I noted also that the painting diagrams at the end were plain black and white? I would have expected those to at least be in colour as Tamiya do for their kits and even Airfix do that nowadays?
Can see this kit becoming a bit of a 'white elephant', especially once the WW kit is released? Companies such as Eduard and Aires are likely going to be very happy with it though as they'll make a mint bringing the HKM kit up to an acceptable standard with their aftermarket parts?
It'll be interesting to see what Daran thinks of his purchase once he has had a proper look at it? ThumbDown
Per Ardua Ad Astra
#64 Posted : 27 December 2018 13:26:34
The other interesting thing is that the Wingnut bomber kit gives you two options of engine type: the RR Merlin XX (for the B.Mk.1) or Packard V-1650-1 Merlin 28 (for the B.Mk.III)
The Wingnut Dambuster version only gives the Packard V-1650-1 Merlin 28.
The HKM bomber version only gives you the RR Merlin XX option for the B.Mk.1 - which already seems to have Mk.II radiators - will be interesting to see if its engine is correct for being an XX?
Kev the Modeller
#65 Posted : 27 December 2018 13:37:19
I suspect not Tom, it's pretty obvious that they haven't done their research properly and just copied what they found on the full size aircraft that they had access to? The reviewer stated that the engines were pretty basic in the level of detail so probably a generic Merlin regardless of it's mark? Sort of if it looks like a Merlin then it must be a Merlin - pretty poor effort really?! Blink Glare
Per Ardua Ad Astra
#66 Posted : 27 December 2018 14:39:21
Other things starting to emerge...
The pilots seat is too long in the seat
The armour plate for the pilots head isn’t indicated as having the yellow circle.
It’s wing tips carry post-war lights
No cockpit canopy framing
Kev the Modeller
#67 Posted : 27 December 2018 17:26:33
Sounds like it's descending into pile of (expensive) rubbish quite quickly! Makes me wonder why it took them about five years to bring it to a point of sale with delay after delay on the release date? Just wondering if there were so many faults with it that they spent that time correcting them and in the end gave up to release it with the faults that went uncorrected? Probably got it out unfinished because they needed to start recouping some of their huge outlay?
Certainly going to put people off buying it who might have done, but will now wait for the seemingly much better WW kit.
Per Ardua Ad Astra
#68 Posted : 28 December 2018 09:21:51
Am sure the Wingnut Lanc kits will be just as just as scrutinised and a bit unfair to suggest the HKM is a pile of ‘rubbish’, am sure that many will turn out a cracking display item. Though with Peter Jackson’s Wingnuts team also being involved with the Dambusters remake, it’s likely the Wingnuts Lanc versions will have the edge.
Kev the Modeller
#69 Posted : 28 December 2018 13:43:55
Yeah, I agree, maybe that was a bit strong Tom, my comment, though it certainly doesn't look like it is up to expectations after such a long wait for the release. I would have thought it would be almost faultless, but not so it seems?
No doubt there will be some nice display models created from the kit as you say, but it will take a bit of work to correct some of the faults if accuracy is desired?
Per Ardua Ad Astra
#70 Posted : 30 December 2018 11:08:59
Iconicair has released a resin 1/32 Dambuster conversion set for the HKM 1/32 Lancaster bomber
http://www.iconicair.com/hkmd/Index.html
A nice conversion kit though for the HK Lanc to be a Dambuster, it also need an engine change to having the Packard V-1650-1 Merlin 28 as HKM kit has a Merlin XX - both are very different engines hence why Wingnuts only provide the Packard V-1650-1 Merlin 28 with their Dambuster kit.
The modifications to the “464 Provisioning” Dambuster Lancasters was extensive and covered major items such as the fitting of the more powerful Packard Merlin 28 engine, removal of the dorsal gun turret, removal of bomb bay doors, fitting of a wind deflector for the mine, support arms, release mechanism and an ex submarine hydraulic motor and belt drives to spin the mine.
Much smaller changes included the fitting of front gunner stirrups to keep his feet out of the bomb aimers face, spent case collecting bags (to stop them falling on the bomb aimers head) and strengthened oleo legs and bomb beams.
Kev the Modeller
#71 Posted : 30 December 2018 11:30:59
They're some beautifully detailed parts from Iconicair, but as you say Tom, a few omissions if it is to sold as a complete conversion kit? Unless the other parts, such as an engine kit are to come as a later release maybe?
Per Ardua Ad Astra
Kev the Modeller
#72 Posted : 30 December 2018 11:39:14
Yeah … it seems that whoever is producing kits or aftermarket parts for the 1:32 Lanc isn't spending enough on their research in the first place! Laugh Glare
Per Ardua Ad Astra
#73 Posted : 07 January 2019 08:44:32
IconicAir have a 1/32 Rolls Royce nameplate set available for the Merlin cam covers....
http://www.iconicair.com/nameplates/
#74 Posted : 07 January 2019 08:57:46
Just ordered a set.BigGrin
#75 Posted : 10 January 2019 09:16:11
There is word that the HK kit has the red gear mtce locks molded onto the U/C retraction struts, something used only on post war aircraft. These locks prevent inadvertent gear retraction on the ground. They shouldn't be there unless you're modelling your kit in major overhaul or restoration.
Kev the Modeller
#76 Posted : 10 January 2019 21:03:44
That's interesting Tom. I wonder if WnW are aware and whether or not they might alter that detail before releasing the kit? ThumpUp
Per Ardua Ad Astra
#77 Posted : 13 January 2019 10:06:28
Camo mask set now available for the 1/32 HKM and Wingnuts Lancaster kits..
https://www.hannants.co.uk/product/TNM32-M090
#78 Posted : 13 January 2019 14:10:14
Airscale Instrument panel upgrade review for 1/32 HKM Lancaster
https://m.youtube.com/watch?v=mmEa5UuEjts
#79 Posted : 17 January 2019 12:59:43
Eduard PE set's for the HKM 1/32 Lancaster kit - due for release late Feb 2019
Eduard ED32938 cockpit set
Eduard ED32939 seat belts
Eduard EDJX225 self-adhesive paint mask set
Pre-order via Hannants..
https://www.hannants.co....ection=asc&pageID=1
#80 Posted : 23 January 2019 21:30:13
IconicAir now also have a:
1/32 Cookie Bomb Trolley
http://www.iconicair.com/cookie/
Upkeep Bomb Trolley to go with the Dambuster conversion
http://www.iconicair.com/dambuster/
and a Field Tractor is on the way too Cool
Guest (6)
5 Pages «<2345>
This page was generated in 0.290 seconds.
