Another interesting car for the Mclaren collection is this MP 4/2. The 1984 season was dominated by Prost and Lauda with 12 wins from 16. The championship went to Lauda by half a point even though he scored 5 wins to Prost's 7. The TAG - Porsche turbo proved itself !! The car followed on from the MP 4/1 and established the Carbon chassis design from John Barnard. This kit from Aoshima Beemax has a great detail up set from the same manufacturer so I'm looking forward to a little extra detailing. At last !! something other than a DFV power unit. Malc. RM1 attached the following image(s):
Here you go Malc:
https://www.spotmodel.co...roducts_id=44920#image2
Not cheap but well worth the money, and it's currently in stock. There is an MFH 'Joe Honda' photo book further down that page, along with various other MP4/2 modelling products that might be useful to your build.
Hope that helps?
Kev  Per Ardua Ad Astra
Kev the Modeller wrote:Here you go Malc:
Hope that helps?
Kev  Many thanks Kev. I haven't explored that spotmodel site before. Looks very useful.
Cheers Malc.
They are really good Malc, very trustworthy, very efficient and you will be updated on the progress of your items all the way from dispatch to arrival. I even got an email to tell me when my items had arrived in the UK and had been passed to a UK carrier - that's efficiency for you.
Highly recommended!
Didn't like the adhesive backed aluminium foil of the kit. It's in a couple of parts and once it touches down...that's it. No movement possible. Used kitchen foil cut to shape, embossed on a mesh and stuck with a liquid glue. Malc.RM1 attached the following image(s):
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,868 Points: 17,756 Location: ipswich
Looks really good.
Just a tip for the future: Heat shielding. Use the foil top peeled off a butter or spread tub and stick it with double sided tape. It's already embossed...
Roy.
roymattblack wrote:Looks really good.
Roy. Thanks Roy ...good tip, I must try that one Malc.
Happy new year to one and all !!
Started work on the tub and getting it ready for the Carbon decals that came with the detail kit. There's a PE section for the nose that requires some sanding down of the plastic on front end so as to get a good fit.
Also painted up some of the front suspension. Still experimenting with the fit of the parts which is generally good on this kit so far.
This weeks update. Carbon decals on the tub and front suspension painted. Dry fit only at this stage. Malc.RM1 attached the following image(s):
Kev the Modeller wrote:The same usual high standard I see Malc, all looking good and I love the carbon decaling, it gives a very realistic look to the cockpit tub.
Keep up the excellent work.
Kev Thanks Kev. The decals were a bit "light brown" so I gave them a very..very slight dust of metallic gold and then toned it down with TS smoke. Malc.
I've been struggling to find time for building recently but have made some progress with some of the parts . Malc.RM1 attached the following image(s):
Starting to Prep' the bodywork.RM1 attached the following image(s):
I've purchased this great detail guide for the MP4/2 !! It's the Komakai book from Spotmodels. ( Many thanks for the advice Kev ).RM1 attached the following image(s):
Front end assembled and wheels + Tyres painted.RM1 attached the following image(s):
 Just lovin' the way this is coming together Malc, the detail looks superb! Regards Gray
