That`s a well detailed figure and a good size for painting. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
A very nice entry Kev, good luck with the comp.... Regards Alan
Great to see a figurine entry, good luck with your D-Day 75 entry
 Looks a nicely detailed figure and good luck with the comp Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Lovely figure Kev, great detail. Good luck in the competition. Mark Regards Markwarren (Mark) Admin
Wow Kev that looks one super-cool figure! Can’t wait to see what you make of it and good luck in the comp Regards Gray
Look forward to seeing what you do with this one kev. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Looks like a very challenging detail painting task there Kev. Good luck with the competition. Malc.
Should be a stunner with your painting skills Kev, nice choice!
Very nicely detailed figure, I look forward to seeing it come together.
That figure looks great, look forward to your build starting. Good luck Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hello all,
My 1:9 resin figure arrived yesterday and my paint sets have arrived this morning, so I'm all ready to go!!
As always with any of Mitches' figure kits the parts are well packed in sealable bags with bubble wrap and a nice sturdy box with a picture of the finished and primed figure on the front. The individual parts are well cast with some very nice detail, just needing a wash in warm soapy water and some clean up of seams and removal of the casting plugs. The photos below will show the contents and all of that lovely detail. I think I may have been given an extra shovel blade(covered) as I have two in my pack and only one shovel handle, the carrying of just one shovel is correct. Also, the .30cal barrel looks to be a bit warped but that should straighten out with a bit of hot water and gentle bending. I have included a photo of the main body parts with a ruler so that you can see just how big these 200mm figures look - there's plenty of room to work on that detail painting when you get to it, that's for sure! I will be displaying this figure on a small base when finished with some simple groundwork included.
The paints that I have chosen are the US Army WWII Uniforms Set 1 (Class 'A' Uniforms) and Set 2 (Combat Gear) with six 22ml pots per set. Both are acrylic paint sets and are produced by 'Lifecolor'. I'm not the biggest fan of Lifecolor paints though they're not the worst, but I know that their paints are always very accurate in their colour so I've decided to use them for this build. I will mainly be relying on set 2 'Combat Gear' but thought it would be useful to have the option of several other colours from set 1 if needed. Most of my painting will be done using these and some artist's acrylic paints along with some Winsor & Newton 'Alkyd' fast drying oils and also some metallic paints from various manufacturers.
So, first job is to give the parts a bath and then set about the clean up, prepping and priming process, which I'll probably start this weekend.
Kev
Kev the Modeller attached the following image(s): Per Ardua Ad Astra
 Like you said Kev, there’s some great detail on this figurine
Hi Kev very nice figure you have there,look forward to following your progress cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
 Looks a nicely molded figure and good luck in the comp Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
That's a great looking figure Kev  look forward to seeing it come together. Al
