LCD display protective covering in issue 6 Options
ronald305
#1 Posted : 30 December 2018 01:40:22
hello there
would anyone know how to tell if there is a protective cover on the LCD display
if there is any I don't think the one I got has a protective cover, I think mine came in the little case with out any thank you
Ronald
Gav777uk
#2 Posted : 30 December 2018 09:47:11
Rank: Beginner Level 1
If you're referring to the rear long LCD display, then yes, it has a thin protective film across it. You should be able to pick up the corner with a finger nail or the edge of a piece of paper. If you've left it on and built the unit, it shouldn't make any difference or be noticeable.
I also placed a piece of 1mm foam to block out the white light from around the edge of the LCD display.
ronald305
#3 Posted : 30 December 2018 14:46:24
well I'm sorry to say the one I got did not come with any protective film I tried to fell around for a tab to pull off but could not find any I do not want to scratch the LCD. but adding a piece of foam around the edges is good idea, back to the LCD I will look again even if I have to take it apart from the inner frame
This page was generated in 0.100 seconds.
