 Rank: Pro Groups: Registered
Joined: 08/02/2015 Posts: 426 Points: 1,259 Location: Louisiana
Hello there does anyone know which screws to us for R2'S right ankle fitting it can't be the two black screws because they are self tapping screws even the instructions are not showing the black screws it is showing a machine screws even the official build diary shows using a machine screw but which size to use would it be the 4mm screws that issue came with I will assemble the ankle fitting untill I know for sure thank you Ronald
Hi Ronald You use the black self tapping screws from issue 7 as stated in the official build. https://forum.model-space.co.uk/...aspx?g=posts&t=21672Mark Regards Markwarren (Mark) Admin
yes to mount the silver parts to the ankle but not to each other silver screws are for that I just what to know which silver screws the long one's Ronald
Joined: 04/08/2017 Posts: 73 Points: 243 Location: Missouri, USA
If you mean which screws to assemble the 3 silver pieces together, then the build diary says the silver screws supplied with issue 7. Just from memory, I think they were also about 6mm long, but I could be mistaken.
Yes that is it thank you I’m thinking 6mm as well do you think they are the screws that go with the nuts that is used to assemble the dome
Almost certain they are different than the dome ones.
Joined: 11/01/2017 Posts: 89 Points: 259 Location: Lancashire, UK
I wish they'd be clearer in the magazines with which screws are to be used instead of having to drop in here all the time. Thankfully, after a few issues, it becomes pretty clear as there is a pattern, but not everyone may see that.
Screw type clarity is noted within the text of the official build
well I am sorry to tell you sir but you are wrong the text does not mention any clarity of which screw to use unless you can copy the text and circle the clarity you are talking about us members here will in the dark on which screw to use besides looking at the picture of the screw Ronald
I do not see yet James but will continue looking Ronald
ronald305 wrote:I do not see yet James but will continue looking Ronald I believe Andy has explained via PM as per your request
Andy explained some things but still did not tell me which screw to use for the silver fittings not counting all of the black screws two of which are used to connect the fitting to the ankle PS the build diary is not clear on the type of screws to use in issue 7 especially the ankle fitting Darth is correct on his post about fixing the screw problem the company are to put labels on each screw bag and what part it is used for Ronald
Hi Ronald Below is the explanation for the use of the screws provided in issue 7 as per the Pm I sent to you last night. In issue 7 you get 10 silver screws, 6 + the supplied nuts are used on the dome assembly leaving 4 screws, 2 more are used on the ankle parts leaving 2 spare. You will always have a spare screw from every assembly that usualy leaves a single screw but in this instance two assemblys equal 2 spares.
So just use the silver screws provided with Issue 7 to complete that stage of the build. Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
the longer ones right Andy the shorter ones are for the silver bracket and coupling Ronald
All the screws provided in issue 7 are the same length so use the same screws you used to assemble the dome to assemble the ankle detail parts. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
