which screws to use Options
ronald305
#1 Posted : 30 December 2018 20:35:43
Hello there
does anyone know which screws to us for R2'S right ankle fitting it can't be the two black screws because they are self tapping screws even the instructions
are not showing the black screws it is showing a machine screws even the official build diary shows using a machine screw but which size to use would it be the 4mm screws that issue came with I will assemble the ankle fitting untill I know for sure thank you
Ronald
#2 Posted : 30 December 2018 21:46:15
Hi Ronald
You use the black self tapping screws from issue 7 as stated in the official build.
https://forum.model-space.co.uk/...aspx?g=posts&t=21672
ronald305
#3 Posted : 31 December 2018 01:23:33
yes to mount the silver parts to the ankle but not to each other silver screws are for that I just what to know which silver screws the long one's
Ronald
tschwand
#4 Posted : 31 December 2018 03:29:44
If you mean which screws to assemble the 3 silver pieces together, then the build diary says the silver screws supplied with issue 7. Just from memory, I think they were also about 6mm long, but I could be mistaken.
ronald305
#5 Posted : 31 December 2018 04:10:52
Yes that is it thank you I’m thinking 6mm as well do you think they are the screws that go with the nuts that is used to assemble the dome
tschwand
#6 Posted : 31 December 2018 04:59:55
Almost certain they are different than the dome ones.
James H
#7 Posted : 31 December 2018 08:21:42
I wish they'd be clearer in the magazines with which screws are to be used instead of having to drop in here all the time.
Thankfully, after a few issues, it becomes pretty clear as there is a pattern, but not everyone may see that.
#8 Posted : 31 December 2018 08:58:48
Screw type clarity is noted within the text of the official build Cool
ronald305
#9 Posted : 31 December 2018 14:50:20
well I am sorry to tell you sir but you are wrong the text does not mention any clarity of which screw to use unless you can copy the text and circle the clarity you are talking about us members here will in the dark on which screw to use besides looking at the picture of the screw
Ronald
ronald305
#10 Posted : 31 December 2018 15:04:36
I do not see yet James but will continue looking
Ronald
#11 Posted : 31 December 2018 15:30:19
Ronald
I believe Andy has explained via PM as per your request
ronald305
#12 Posted : 31 December 2018 16:11:14
Andy explained some things but still did not tell me which screw to use for the silver fittings not counting all of the black screws two of which are used to connect the fitting to the ankle PS the build diary is not clear on the type of
screws to use in issue 7 especially the ankle fitting Darth is correct on his post about fixing the screw problem the company are to put labels on each screw bag and what part it is used for
Ronald
#13 Posted : 31 December 2018 16:40:43
Hi Ronald
Below is the explanation for the use of the screws provided in issue 7 as per the Pm I sent to you last night.
In issue 7 you get 10 silver screws, 6 + the supplied nuts are used on the dome assembly leaving 4 screws, 2 more are used on the ankle parts leaving 2 spare. You will always have a spare screw from every assembly that usualy leaves a single screw but in this instance two assemblys equal 2 spares.
So just use the silver screws provided with Issue 7 to complete that stage of the build.
ronald305
#14 Posted : 31 December 2018 16:48:40
the longer ones right Andy the shorter ones are for the silver bracket and coupling
Ronald
#15 Posted : 31 December 2018 16:52:54
All the screws provided in issue 7 are the same length so use the same screws you used to assemble the dome to assemble the ankle detail parts.
This page was generated in 0.567 seconds.
